Thread: L Shaped Curtain Wall from In-Place Mass Help
    June 25, 2016
    UK
    5
    10:12 PM
    Hey guys,
    Am currently working on a project and having a problem.
    I'm trying to create a unique curtain wall and have started off creating an L Shape. After that, I turn it into a Solid Form and I want to move the front top edge down to create a triangle. Problem is that when I do this, it always creates an unwanted diagonal edge which then will not allow me to create the curtain walls correctly. I've tried doing it by selecting the edges and moving it down, selecting all top vertices and moving them down, even in X-Ray and all the time it does the same.
    Is there any way to delete the unwanted edge or another way to do it perhaps? All out of ideas .
    3,231
    06:12 PM
    If you are modeling this as a mass, model just surfaces. In the project you can add thickness by using wall by face. To get the surfaces modeled correctly start with locating the most primitive elements: points. Then, lines, then surfaces. That process will get to better results than modeling volumes and trying to edit those volumes, like you are doing. The unwanted edge is probably because the front faces of the L became non co-planar when you moved some vertices.
  1. In Place Mass Disappears when Subcategory is changed to Mass Exterior Wall
    By pmrossarc in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 26th, 2017, 09:41 AM
  2. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
  3. Random slat on wall (Loblolly): Conceptual Mass and Curtain Wall/Surface
    By im4am303 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 15th, 2015, 09:45 PM
  4. Conceptual Mass and Curtain Wall?
    By CVF225 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 7th, 2011, 06:59 PM
