Thread: Pattern Based Rectangular Curtain Panel - Split into Triangles based on Distortion
    Junior Member christianism's Avatar
    March 1, 2018
    Tokyo
    5
    12:46 AM
    Hello,
    Still new to this forum and to the pattern based panel design but thought this is worth sharing. Apologies if this has already been described in other post etc...
    I am currently working on a project with paneling that changes angles and as a result has twisted surfaces in certain transition zones. I want the majority of panels to show without a (diagonal) fold/joint as long as they are reasonably flat. Once the panels become too twisted, I need them to change to triangles. I still want ONE divided surface as a base to enable quick changes in panel sizing etc.
    1st problem: The ONE surface can only have one pattern - rectangular or triangular. As my panels have basically 4 corners, I have chosen the rectangular pattern.
    2nd problem: How do I break the twisted ones into triangles? Here I had to look at Alfredo Medina's posts and Zach Kron's excellent exercises on flat panelling (buildz: Planar Panels & the 3 Point Invisible Workplane Hack©). Learning the "invisible reference plane" method to flatten panels, I could use this to analyse the geometry of each panel and set a threshold value ("Panel Distortion" parameter) that controls the visibility of either a rectangular or two triangular panels in the family.
    Attached sample files (Revit 2017.2) show that the panels begin to break up into triangles once a certain threshold of distortion is reached.
    Took me while to work this out but hope this can be of use for anyone on this forum.
Name:	twisted surface paneling.JPG
    March 1, 2018
    Tokyo
    5
    12:46 AM
    I noticed I made a mistake in the panel family (dimension reference to an adaptive point instead of a reference line). Also, i have amended the sample file to show a surface that gradually changes from flat to twisted (previous sample was all twisted).
    The attached Revit2017.2 files should be ok now.
    Also attached is a screenshot from the project where I used this panel... works for me!
Name:	project - twisted surface paneling.JPG
  1. Pattern Based Curtain Panel - Keep Panel Extrusion aligned
    By christianism in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 12th, 2018, 02:49 AM
  2. Fluxing the Curtain Panel Pattern Based ?
    Last Post: June 13th, 2017, 05:32 PM
  3. Curtain panel pattern based
    By Lochan91 in forum Architecture and General Revit Questions
    Last Post: November 20th, 2016, 03:20 PM
  4. Is there a way to schedule each panel in a Pattern Based Curtain wall?
    By viratmanchanda in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 22nd, 2014, 10:59 AM
  5. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
