Thread: locker family not associating with host room (2017)
    June 26, 2014
    97
    02:03 PM
    i have a locker family and i would like to create a schedule that shows the lockers that are in each locker room (mens & womens.) i have created a furniture schedule and included these fields; room name, room number, family and type, mark, count, type mark. when the schedule is created the columns for room name & room number are blank. it seems as though my lockers are not associating with the room that they are located in. i have moved the room calculation point so that it is not on the ground plane and not in the center of the locker family and still no luck. i was hoping someone has a solution?
    i am attaching the locker family for your review.
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    09:03 PM
    Seems to work fine for me
    June 26, 2014
    97
    02:03 PM
    so i copied the rooms with the lockers into a new project and created a schedule and it seemed to work in the new file. so there is something wrong with my project file.
    Wellington, New Zealand
    704
    10:03 AM
    Are the lockers on the same phase as the rooms? (both are phase dependent)
    June 26, 2014
    97
    02:03 PM
    yes they are in the same phase. I found out that I had to move the "room calculation point" in the locker family.
    704
    10:03 AM
    Ah - good catch. You probably dont actually need a room calculation point in there at all..
  1. change room's host level
    Last Post: March 7th, 2018, 05:11 PM
  2. Linked Room Tags Overlapping Host Model Items
    By lizbrack in forum Architecture and General Revit Questions
    Last Post: May 10th, 2017, 09:04 PM
  3. Bug when associating parameters of shared nested family
    By ekkonap in forum Architecture and General Revit Questions
    Last Post: May 5th, 2017, 12:43 PM
    Last Post: April 6th, 2017, 12:15 AM
  5. Replies: 1
    Last Post: September 30th, 2016, 04:33 PM
