Previously the Desktop Connector was built for BIM 360 Team projects running C4R. With the shift to B3D (BIM 360 Docs) platform, you need to:
  • Install Desktop Connector
  • Install beta version of a plugin for Desktop connector that allows access to BIM 360 Docs under a separate link
From the help:
This plugin is a connector that establishes BIM 360 Docs as a recognized data source for the Desktop Connector – making it available in your desktop folder and file structure for easy file management.
As with Desktop Connector, this means your BIM 360 Docs files are replicated in a connected drive. You can manage files in BIM 360 Docs through the connected drive, just as you would any other folder on your machine. Changes made on the desktop are automatically uploaded to BIM 360 Docs.
How do you get it?
After install, you will see this in Windows Explorer:
The post How to use Autodesk Desktop Connector with BIM 360 Docs appeared first on What Revit Wants.
