Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 154
Thread: RFO Benchmark v3.2 2019 results
  1. #21
    January 5, 2018
    12:59 AM
    Code:
    RVT 2019 - Full_Simplified set - 2018.06.13 @ 00.43.05 on KAYA-EV.txt
        RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Run on Revit 2019 FCS
    Model creation benchmark
        4.51   opening and loading the custom template
       15.76   creating the floors levels and grids
       30.81   creating a group of walls and doors
       55.08   modifying the group by adding a curtain wall
       18.53   creating the exterior curtain wall
       14.12   creating the sections
        6.23   changing the curtain wall panel type
       19.31   creating area plans
        2.74   creating and applying view template
      167.09   TOTAL
    Graphics
        5.93   activate View Styles view
        2.34   change view to Wireframe
        0.20   change view to Hidden
        0.81   change view to Shaded
        0.86   change view to Consistent Colors
        0.80   change view to Realistic
        2.05   refresh Wireframe Line view x10
        8.51   refresh Hidden Line view x10
        9.10   refresh Shaded view x10
        8.57   refresh Consistent Colors view x10
       10.33   refresh Realistic view x10
        0.98   activate View Cube view
        6.14   rotate view x1
       56.62   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
    Max Clock Speed: 3.4Ghz
    Number of Processors: 4
    Total Physical Memory: 16GB @ 1333 1333 1333Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Intel Raid 0 Volume
    Graphics Card: Radeon (TM) RX 480 Graphics
    Graphics RAM: 3.9990234375GB
    Driver version: 24.20.11019.1004
    Screen Resolution: 3440x1440x32bit @ 60Hz
    DPI Scaling: 100%
  2. #22
    September 12, 2014
    11:59 AM
    just an observation .... for all these tests, and ive just run mine with 16GB and will run another 32GB ... but they only use 4GB RAM for the Graphics Card?
    Is that a limitation of the test?
    Anyways - 16GB Version
    Code:
    T 2019 - Full_Standard set - 2018.06.21 @ 14.34.44 on DD-CAD-1.txt
        RevitForum.org
    Update
        8.50   update previous version file
        4.39   opening and loading the custom template
       15.26   creating the floors levels and grids
       23.49   creating a group of walls and doors
       39.72   modifying the group by adding a curtain wall
       14.81   creating the exterior curtain wall
       12.59   creating the sections
        4.47   changing the curtain wall panel type
       17.52   creating area plans
        2.47   creating and applying view template
      134.72   TOTAL
    Export benchmark
       75.05   export all views as PNGs at 300 dpi
       57.83   export all views as DWFs
      106.20   export all views as DWGs
       66.57   print all views as vector *
      110.93   print all views as raster *
    Notes:
    Render benchmark
       68.89   render
    Graphics - Standard View
        5.41   activate View Styles view
        0.55   change view to Wireframe
        0.88   change view to Hidden
        1.25   change view to Shaded
        1.20   change view to Consistent Colors
        2.20   change view to Realistic
        1.05   refresh Wireframe Line view x10
        4.27   refresh Hidden Line view x10
        4.42   refresh Shaded view x10
        4.30   refresh Consistent Colors view x10
        4.65   refresh Realistic view x10
        0.59   activate View Cube view
        4.04   rotate view x1
       34.81   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP Z440 Workstation
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Xeon(R) CPU E5-1650 v4 @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 16GB @ 2400 2400Mhz
    Drive Model: SAMSUNG MZVKW512HMJP-000H1
    Graphics Card: NVIDIA Quadro P4000
    Driver version: 23.21.13.8826
    Screen Resolution: 2560x1440x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
        9.324    8.148    8.016   update previous version file
        4.312    4.301    4.543   opening and loading the custom template
       15.367   15.305   15.117   creating the floors levels and grids
       23.578   23.309   23.594   creating a group of walls and doors
       39.957   39.398   39.797   modifying the group by adding a curtain wall
       15.465   14.543   14.430   creating the exterior curtain wall
       12.957   12.422   12.379   creating the sections
        4.535    4.422    4.461   changing the curtain wall panel type
       17.078   18.137   17.336   creating area plans
        2.465    2.449    2.488   creating and applying view template
       77.617   74.066   73.477   export all views as PNGs at 300 dpi
       58.406   57.539   57.555   export all views as DWFs
      110.344  104.008  104.238   export all views as DWGs
       69.715   64.820   65.164   print all views as vector
      113.875  107.828  111.078   print all views as raster
       69.762   68.191   68.711   render
        5.188    5.496    5.543   activate View Styles view
        0.547    0.570    0.531   change view to Wireframe
        0.891    0.871    0.875   change view to Hidden
        1.223    1.266    1.254   change view to Shaded
        1.172    1.242    1.191   change view to Consistent Colors
        2.199    2.180    2.207   change view to Realistic
        1.035    1.074    1.039   refresh Wireframe Line view x10
        4.371    4.266    4.164   refresh Hidden Line view x10
        4.344    4.434    4.480   refresh Shaded view x10
        4.316    4.324    4.273   refresh Consistent Colors view x10
        4.508    4.648    4.797   refresh Realistic view x10
        0.566    0.613    0.586   activate View Cube view
        3.723    4.102    4.285   rotate view x1
    Home Machine - i7 6700k, 1080ti, 32GB RAM
    Code:
    RVT 2019 - Full_Standard set - 2018.06.23 @ 07.58.48 on SS_MEDIA_SERVER.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        7.43   update previous version file
        3.68   opening and loading the custom template
       11.91   creating the floors levels and grids
       19.30   creating a group of walls and doors
       32.97   modifying the group by adding a curtain wall
       12.37   creating the exterior curtain wall
        8.99   creating the sections
        3.91   changing the curtain wall panel type
       13.18   creating area plans
        1.87   creating and applying view template
      108.18   TOTAL
    Export benchmark
       56.42   export all views as PNGs at 300 dpi
       46.72   export all views as DWFs
       83.00   export all views as DWGs
       51.55   print all views as vector *
       88.11   print all views as raster *
    Notes:
    Render benchmark
       84.08   render
        4.33   activate View Styles view
        0.47   change view to Wireframe
        0.80   change view to Hidden
        1.06   change view to Shaded
        1.02   change view to Consistent Colors
        1.65   change view to Realistic
        0.86   refresh Wireframe Line view x10
        3.25   refresh Hidden Line view x10
        3.41   refresh Shaded view x10
        3.22   refresh Consistent Colors view x10
        3.56   refresh Realistic view x10
        0.48   activate View Cube view
        2.65   rotate view x1
       26.76   TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: NVMe Samsung SSD 950
    Graphics Card: NVIDIA GeForce GTX 1080 Ti
    Driver version: 23.21.13.8813
    Screen Resolution: 5760x1080x32bit @ 119Hz
    DPI Scaling: 100%
    RAW DATA:
        8.309    6.996    6.980   update previous version file
        3.680    3.738    3.625   opening and loading the custom template
       11.633   11.635   12.455   creating the floors levels and grids
       19.289   19.344   19.277   creating a group of walls and doors
       32.990   32.926   32.988   modifying the group by adding a curtain wall
       12.520   12.268   12.320   creating the exterior curtain wall
        9.086    9.027    8.850   creating the sections
        3.900    3.908    3.912   changing the curtain wall panel type
       13.256   13.115   13.170   creating area plans
        1.891    1.887    1.842   creating and applying view template
       56.523   56.646   56.090   export all views as PNGs at 300 dpi
       47.125   46.539   46.484   export all views as DWFs
       82.436   83.365   83.193   export all views as DWGs
       51.705   51.268   51.666   print all views as vector
       87.594   87.984   88.740   print all views as raster
       87.408   81.457   83.389   render
        4.475    4.385    4.133   activate View Styles view
        0.463    0.508    0.434   change view to Wireframe
        0.787    0.820    0.779   change view to Hidden
        1.190    0.998    1.000   change view to Shaded
        1.010    1.049    0.990   change view to Consistent Colors
        1.662    1.668    1.617   change view to Realistic
        0.863    0.850    0.856   refresh Wireframe Line view x10
        3.371    3.213    3.174   refresh Hidden Line view x10
        3.461    3.455    3.326   refresh Shaded view x10
        3.252    3.240    3.170   refresh Consistent Colors view x10
        3.602    3.584    3.482   refresh Realistic view x10
        0.492    0.504    0.430   activate View Cube view
        2.701    2.656    2.586   rotate view x1
  3. #23
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    253
    12:59 AM
    Just did the simplified test and it all looks good to me.
    This test is @ standard clockspeeds and i did a second test @ 5Ghz
    Code:
    RVT 2019 - Full_Simplified set - 2018.06.21 @ 09.13.34 on DESKTOP.txt
        RevitForum.org
    Run on Revit 2019.0.1
        5.02   opening and loading the custom template
       10.70   creating the floors levels and grids
       16.82   creating a group of walls and doors
       30.16   modifying the group by adding a curtain wall
       11.29   creating the exterior curtain wall
        9.32   creating the sections
        3.53   changing the curtain wall panel type
       12.87   creating area plans
        1.77   creating and applying view template
      101.48   TOTAL
    Graphics
        4.36   activate View Styles view
        1.20   change view to Wireframe
        0.09   change view to Hidden
        0.36   change view to Shaded
        0.39   change view to Consistent Colors
        0.36   change view to Realistic
        0.93   refresh Wireframe Line view x10
        3.76   refresh Hidden Line view x10
        3.96   refresh Shaded view x10
        3.76   refresh Consistent Colors view x10
        4.72   refresh Realistic view x10
        0.43   activate View Cube view
        3.16   rotate view x1
       27.48   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    Max Clock Speed: 4.201Ghz
    Drive Model: Samsung SSD 970 PRO 512GB
    Graphics Card: NVIDIA GeForce GTX 1070 Ti
    Driver version: 23.21.13.9135
    DPI Scaling: 125%
    5Ghz test
    Code:
    RVT 2019 - Full_Simplified set - 2018.07.03 @ 10.24.23 on DESKTOP-BENEDEN.txt
        RevitForum.org
        4.28   opening and loading the custom template
        9.74   creating the floors levels and grids
       14.89   creating a group of walls and doors
       26.89   modifying the group by adding a curtain wall
        9.21   creating the exterior curtain wall
        7.14   creating the sections
        3.13   changing the curtain wall panel type
       11.08   creating area plans
        1.57   creating and applying view template
       87.93   TOTAL
    Graphics
        4.04   activate View Styles view
        1.06   change view to Wireframe
        0.08   change view to Hidden
        0.32   change view to Shaded
        0.34   change view to Consistent Colors
        0.32   change view to Realistic
        0.80   refresh Wireframe Line view x10
        3.37   refresh Hidden Line view x10
        3.51   refresh Shaded view x10
        3.35   refresh Consistent Colors view x10
        4.24   refresh Realistic view x10
        0.39   activate View Cube view
        2.84   rotate view x1
       24.66   TOTAL
    Notes:
    TEST CONDITIONS:
    DPI Scaling: 125%
    Overclocking gives a real boost at the benchmark score.
    I also did a run on my old laptop.
    Code:
    RVT 2019 - Full_Standard set - 2018.07.06 @ 18.20.41 on DESKTOP-Q6S9T6F.txt
        RevitForum.org
    Update
       11.56   update previous version file
        4.77   opening and loading the custom template
       15.67   creating the floors levels and grids
       31.17   creating a group of walls and doors
       57.85   modifying the group by adding a curtain wall
       20.57   creating the exterior curtain wall
       15.28   creating the sections
        6.62   changing the curtain wall panel type
       21.06   creating area plans
        2.92   creating and applying view template
      175.91   TOTAL
    Export benchmark
       94.09   export all views as PNGs at 300 dpi
       84.00   export all views as DWFs
      168.47   export all views as DWGs
       98.14   print all views as vector *
      144.35   print all views as raster *
    Notes:
    Render benchmark
      166.85   render
        6.56   activate View Styles view
        0.79   change view to Wireframe
        1.71   change view to Hidden
        2.18   change view to Shaded
        2.12   change view to Consistent Colors
        3.26   change view to Realistic
        1.81   refresh Wireframe Line view x10
        6.77   refresh Hidden Line view x10
        7.33   refresh Shaded view x10
        6.90   refresh Consistent Colors view x10
        7.60   refresh Realistic view x10
        0.90   activate View Cube view
        7.06   rotate view x1
       54.99   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: HP EliteBook 8560w
    CPU: Intel(R) Core(TM) i7-2820QM CPU @ 2.30GHz
    Max Clock Speed: 2.301Ghz
    Total Physical Memory: 8GB @ 1333 1333Mhz
    Drive Model: SAMSUNG MZ7PC256HAFU-000H1
    Graphics Card: NVIDIA Quadro 1000M
    Graphics RAM: 2GB
    Driver version: 21.21.13.7699
    Screen Resolution: 1920x1080x32bit @ 59Hz
    DPI Scaling: 125%
    RAW DATA:
       11.680   11.484   11.516   update previous version file
        4.805    4.805    4.711   opening and loading the custom template
       15.422   16.070   15.508   creating the floors levels and grids
       31.070   31.391   31.047   creating a group of walls and doors
       57.625   57.688   58.242   modifying the group by adding a curtain wall
       21.172   21.555   18.992   creating the exterior curtain wall
       15.625   16.758   13.453   creating the sections
        6.719    6.711    6.430   changing the curtain wall panel type
       20.578   21.844   20.766   creating area plans
        2.844    2.984    2.938   creating and applying view template
       92.734   94.781   94.750   export all views as PNGs at 300 dpi
       83.859   83.578   84.570   export all views as DWFs
      168.328  168.977  168.109   export all views as DWGs
       97.430   98.562   98.422   print all views as vector
      144.906  143.461  144.680   print all views as raster
      157.617  158.562  184.359   render
        6.531    6.625    6.531   activate View Styles view
        0.789    0.797    0.773   change view to Wireframe
        1.711    1.703    1.711   change view to Hidden
        2.227    2.094    2.211   change view to Shaded
        2.133    2.102    2.133   change view to Consistent Colors
        3.250    3.195    3.344   change view to Realistic
        1.820    1.812    1.805   refresh Wireframe Line view x10
        6.812    6.758    6.742   refresh Hidden Line view x10
        7.398    7.320    7.273   refresh Shaded view x10
        6.898    6.953    6.844   refresh Consistent Colors view x10
        7.648    7.586    7.570   refresh Realistic view x10
        0.922    0.883    0.883   activate View Cube view
        7.117    7.023    7.039   rotate view x1
  4. #24
    February 26, 2017
    8
    07:59 PM
    New laptop from San Diego.
    Code:
    RVT 2019 - Full_Simplified set - 2018.07.19 @ 00.14.41 on FA-21.txt
        RevitForum.org
        4.31   opening and loading the custom template
       15.04   creating the floors levels and grids
       22.35   creating a group of walls and doors
       36.64   modifying the group by adding a curtain wall
       15.08   creating the exterior curtain wall
       12.81   creating the sections
        4.88   changing the curtain wall panel type
       17.38   creating area plans
        2.79   creating and applying view template
      131.28   TOTAL
    Graphics
        4.64   activate View Styles view
        1.62   change view to Wireframe
        0.12   change view to Hidden
        0.52   change view to Shaded
        0.50   change view to Consistent Colors
        0.47   change view to Realistic
        1.20   refresh Wireframe Line view x10
        5.26   refresh Hidden Line view x10
        5.60   refresh Shaded view x10
        5.41   refresh Consistent Colors view x10
        6.17   refresh Realistic view x10
        0.56   activate View Cube view
        5.14   rotate view x1
       37.21   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Notebook
    Model: P95xER
    CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
    Max Clock Speed: 2.201Ghz
    Total Physical Memory: 32GB @ 2400 2400Mhz
    Drive Model: Samsung SSD 860 PRO 1TB
    Graphics Card: NVIDIA GeForce GTX 1070 with Max-Q Design
    Driver version: 24.21.13.9811
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 23.20.16.4974
    Screen Resolution:  3840x 2160x32bit @  60Hz
    DPI Scaling: 100%
  5. #25
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    274
    05:59 PM
    Quote Originally Posted by CV304 View Post
    How does performance feel? And is this an individual purchase or your office that is letting you use it?
  6. #26
    February 26, 2017
    8
    07:59 PM
    It is an incredible laptop- basically my work computer. BimBox Slim 15” laptop. It is truly an engineering marvel: insanely thin,lightweight and really fast. I feel guilty loving a piece of tech this much.
  7. #27
    Junior Member fafa007's Avatar
    June 9, 2011
    Panam
    28
    12:59 AM
    Hello,
    My results with the last computer I ordered:
    Code:
    RVT 2019 - Full_Standard set - 2018.07.19 @ 18.59.18 on 106412-ENIA.txt
        RevitForum.org
    Update
        7.33   update previous version file
        3.46   opening and loading the custom template
        9.76   creating the floors levels and grids
       16.17   creating a group of walls and doors
       29.59   modifying the group by adding a curtain wall
       10.15   creating the exterior curtain wall
        8.22   creating the sections
        3.39   changing the curtain wall panel type
       12.21   creating area plans
        1.66   creating and applying view template
       94.61   TOTAL
    Export benchmark
       56.46   export all views as PNGs at 300 dpi
       43.76   export all views as DWFs
      113.13   export all views as DWGs
       52.83   print all views as vector *
       86.51   print all views as raster *
    Notes:
    Render benchmark
       52.65   render
        3.98   activate View Styles view
        0.39   change view to Wireframe
        0.66   change view to Hidden
        0.85   change view to Shaded
        0.85   change view to Consistent Colors
        1.48   change view to Realistic
        0.68   refresh Wireframe Line view x10
        2.95   refresh Hidden Line view x10
        3.09   refresh Shaded view x10
        2.94   refresh Consistent Colors view x10
        3.26   refresh Realistic view x10
        0.40   activate View Cube view
        2.68   rotate view x1
       24.21   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd.
    Model: MS-7B24
    OS: Microsoft Windows 10 Professionnel64-bit
    CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
    Max Clock Speed: 3.696Ghz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GTX 1060 6GB
    Driver version: 24.21.13.9836
    @cellersick & @Jasep I want to understand why I have slower results than you with a quite similar configuration.
    @cellersick my config is newer than your but you are better except for render & view.
    @Jasep we have same processor but you have faster RAM, is-it this that make the difference?
    By the way do you know if its better to have higher speed or better latency for a regular price (actually I have 2666Mhz CL13)?
    Im trying to build a new config for 5PC, thanks for your advice guys 😉
  8. #28
    1,629
    02:59 AM
    I'm guessing that the difference between your and Cellersick is just the clockspeed of the processor. Yours is 3.70 Ghz and his is 4,20 Ghz and Revit is all about Ghz. I see no harddisk mentioned at Jasoer's machine and it says network drive on yours, so that could be an issue, don't you have a local harddrive/SSD?
    I also notices when testing my laptop that graphics drivers can influence the score a lot, so maybe experiment with a newer or older driver?
  9. #29
    July 30, 2018
    08:59 PM
    Good Machine
    What is "Revit FCS"? Is this "First Customer Ship", perhaps due to running a Trial copy of Revit? That Trial window probably slowed me down since I had to click it every time the benchmark opened Revit. Just wanted to test out the new machine.
    Code:
    RVT 2019 - Full_Simplified set - 2018.07.29 @ 22.27.47 on DESKTOP-0DQ4UA2.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
        5.73   opening and loading the custom template
        8.72   creating the floors levels and grids
       13.98   creating a group of walls and doors
       25.81   modifying the group by adding a curtain wall
        8.19   creating the exterior curtain wall
        6.29   creating the sections
        2.81   changing the curtain wall panel type
        9.38   creating area plans
        1.41   creating and applying view template
       82.32   TOTAL
    Graphics
        4.92   activate View Styles view
        0.89   change view to Wireframe
        0.07   change view to Hidden
        0.28   change view to Shaded
        0.30   change view to Consistent Colors
        0.29   change view to Realistic
        0.70   refresh Wireframe Line view x10
        2.97   refresh Hidden Line view x10
        2.91   refresh Consistent Colors view x10
        3.84   refresh Realistic view x10
        0.34   activate View Cube view
        2.00   rotate view x1
       22.60   TOTAL
    Notes:
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
    Max Clock Speed: 4.008Ghz
    Total Physical Memory: 32GB @ 3383 3383Mhz
    Screen Resolution: 1680x1050x32bit @ 59Hz
    DPI Scaling: 100%
  10. #30
    July 30, 2018
    09:59 PM
    Code:
    RVT 2019 - Full_Standard set - 2018.07.30 @ 20.31.47 on HAADOK-PC.txt
        RevitForum.org
    Update
        3.98   opening and loading the custom template
       10.88   creating the floors levels and grids
       18.16   creating a group of walls and doors
       32.79   modifying the group by adding a curtain wall
       11.66   creating the exterior curtain wall
        8.52   creating the sections
        3.86   changing the curtain wall panel type
       12.23   creating area plans
        1.65   creating and applying view template
      103.73   TOTAL
    Export benchmark
       59.44   export all views as PNGs at 300 dpi
       47.74   export all views as DWFs
       84.87   export all views as DWGs
       53.18   print all views as vector *
       83.26   print all views as raster *
    Notes:
    Render benchmark
       86.43   render
        4.43   activate View Styles view
        0.48   change view to Wireframe
        0.95   change view to Hidden
        1.18   change view to Shaded
        1.11   change view to Consistent Colors
        1.79   change view to Realistic
        0.91   refresh Wireframe Line view x10
        3.43   refresh Hidden Line view x10
        3.68   refresh Shaded view x10
        3.52   refresh Consistent Colors view x10
        3.90   refresh Realistic view x10
        5.92   rotate view x1
       31.78   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: ASUS
    Model: All Series
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
    Total Physical Memory: 8GB @ 1600 1600Mhz
    Drive Model: SanDisk SDSSDA240G
    Graphics Card: NVIDIA Quadro K2000D
    Graphics RAM: 2GB
    Driver version: 23.21.13.8816
    DPI Scaling: 100%
    RAW DATA:
        7.320    7.352    7.633   update previous version file
        3.430    4.992    3.516   opening and loading the custom template
       10.508   10.938   11.203   creating the floors levels and grids
       18.039   18.219   18.219   creating a group of walls and doors
       32.719   32.922   32.719   modifying the group by adding a curtain wall
       11.516   11.852   11.617   creating the exterior curtain wall
        8.188    8.664    8.703   creating the sections
        3.836    3.867    3.875   changing the curtain wall panel type
       11.938   12.398   12.352   creating area plans
        1.594    1.695    1.656   creating and applying view template
       59.297   60.195   58.836   export all views as PNGs at 300 dpi
       47.961   47.766   47.500   export all views as DWFs
       84.453   85.547   84.617   export all views as DWGs
       52.859   53.328   53.359   print all views as vector
       86.156   81.688   81.945   print all views as raster
       86.625   86.258   86.398   render
        4.422    4.453    4.422   activate View Styles view
        0.484    0.484    0.484   change view to Wireframe
        0.938    0.953    0.945   change view to Hidden
        1.117    1.234    1.195   change view to Shaded
        1.094    1.141    1.102   change view to Consistent Colors
        1.781    1.820    1.773   change view to Realistic
        0.891    0.930    0.906   refresh Wireframe Line view x10
        3.398    3.500    3.398   refresh Hidden Line view x10
        3.562    3.859    3.617   refresh Shaded view x10
        3.438    3.656    3.461   refresh Consistent Colors view x10
        3.820    4.086    3.805   refresh Realistic view x10
        0.531    0.461    0.438   activate View Cube view
        5.922    5.977    5.867   rotate view x1
  1. RFO Benchmark v3.1 2018 results
    Last Post: May 21st, 2020, 05:45 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
