Thread: Combining parameters
    May 14, 2018
    24
    07:43 PM
    Not sure if my question relates but I am looking into generating a code from the revit properties
    Example a box :W=10, H= 20, D= 10, Keyword = U
    Now I want to tell the revit to create the Code : 10U20 (what to write in formula section)from the properties provided in the section already - i can currently do this in schedule using the fields combining option but not sure if I can have it generate this information in properties section itself.
    March 25, 2014
    12
    08:43 PM
    You cannot concatenate parameters with formula in Revit, however you could do this using Dynamo. Basically you need to have a new parameter in your family to host the combined parameter, then your dynamo script needs to select all the instances of that family, get the values of the 3 parameters (GetParameterValueByName), then use dynamo to combine the 3 parameters in the order you want and write the combined value to your new parameter (SetParameterValueByName). If you have a look on the DynamoBIM forums (www.dynamobim.org/forum) there should be some similar examples of each stage if you search.
    Darren
    May 14, 2018
    24
    07:43 PM
    Thank you for your response .. will be trying it
    Will try it and keep you posted. Thanks
    Quote Originally Posted by dazza1639 View Post
    Darren
    August 15, 2012
    03:43 PM
    Combining Parameters with Dynamo
    I need to do this exact thing. Did it work?
    I am curious if you can make product numbers using the existing height and width parameters. Do you need to run Dynamo within the project, or within the family? Do you need to place all the families and run dynamo at the end of a project?
    Lots of questions...
    Please advise.
    Thanks!
  1. Combining roofs
    By Newbie Pete in forum Architecture and General Revit Questions
    Last Post: April 17th, 2018, 10:29 PM
  2. Combining two domes
    By aws401 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 26th, 2016, 06:29 PM
  3. Combining Two Parameters by Formulas...is it possible?
    By Revitista in forum Architecture - Family Creation
    Last Post: March 17th, 2015, 07:33 PM
  4. Combining Linked Models
    By chompi0n in forum MEP - General
    Last Post: April 25th, 2014, 05:28 PM
  5. Combining Type and Instance Parameters in Formulas
    By Revitista in forum Architecture and General Revit Questions
    Last Post: March 14th, 2014, 06:00 PM
