Results 1 to 10 of 14
Thread: any idea on how to rotate Generic model in place from horizontal into vertical?
    April 25, 2011
    Egypt
    752
    11:41 PM
    Hi every one ,i made object using model in place choosing generic model any idea on how to rotate Generic model in place from horizontal into vertical?
    and thanks in advance
    11,165
    06:41 PM
    In-Place families form relationships to both other objects and work planes, so it probably wont let you if the rotate button doesnt work. You should make it a Face Based Family, and rarely use in-place.
    April 25, 2011
    Egypt
    752
    11:41 PM
    Good idea can i copy it into the face based families without have to redraw them ??
    11:41 PM
    Nope, probably not.
    But you might want to try exporting the in-place family and then nest it into another face based family... (although best would be to redo it)
    3,231
    07:41 PM
    This is interesting: Revit does not let you rotate from an elevation view a generic model that was created in plan view, not even using "Disjoin". However, if you convert the generic model into a group, now it rotates easily from the elevation, not even using "Disjoin". So, group it and rotate it.
    "OMG I killed Revit"
    dzatto's Avatar
    5,275
    06:41 PM
    Hmm, I haven't checked you work. But, going on your recored here Alf, I bet it works! So, POTM nomination and some little green bars for figuring it out! Good job.
    April 25, 2011
    Egypt
    752
    11:41 PM
    now i will tell you the method i just discovered when i was trying it is easy to do than i have to repeat and become frustrated although this feature will not let you take them grouped but one by one and i have to select edit in place first for the object
    11,165
    06:41 PM
    That wont always work, hence why we are telling you not to use in-place families. But glad it worked out this time.
    Revit Guru
    July 28, 2011
    Brisbane, Australia
    49
    09:41 AM
    To rotate any non-hosted family:
    Edit the Family, set it to Work Plane Based, deselect Always Vertical,
    Host it to a reference plane,
    Then rotate the reference plane...
    October 20, 2011
    UAE
    169
    04:41 AM
    Well Hi,
    I think the easiest way to rotate work plane based element in Revit is to unpin (unlock) it from it's host. When yout create an extrusion or any other form in family editor or in-place editor usually u select some work plane or face to start the sketch and when you finish the sketch and make the form just after that you will see that little sign like a this # with a lock near it just click on it to unpin (unlock) your form from the work plane it was sketched in and click finish. Now in the project you can place and rotate it however you want.
  1. extruded generic model and mass floors
    By turner201 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 1st, 2011, 08:17 AM
  2. Generic model wall based
    By bangobeat in forum Architecture - Family Creation
    Last Post: July 29th, 2011, 06:25 PM
  3. Generic Annotation Always Vertical
    By mark b in forum Out There
    Last Post: March 8th, 2011, 03:19 PM
  4. Generic Annotation Always Vertical
    Last Post: February 9th, 2011, 10:17 PM
