Thread: Labels
    April 24, 2018
    34
    04:50 PM
    Labels
    Is it possible to add a label to a detail component (example: 2X4 wood side view) that changes depending on the length of the stud. So if my detail component was 4 feet long, my label in the family would read as 4 feet?
    1,509
    09:50 PM
    Yes, nest a generic annotation with a label in your detail item and link the parameters from the label to the ones from you detail item.
    Small example is attached
    April 24, 2018
    34
    04:50 PM
    Worked great! Thanks
    1,509
    09:50 PM
    Good to hear !
    April 24, 2018
    34
    04:50 PM
    Okay one more question for you, I typically use a tolerance of up to 1/16", this label seems to want to read up to the 1/32". I change the settings in the label, load it back into the family and overwrite the parameters and it works fine, but when I load and overwrite back into the project, it goes back to a 1/32". Any suggestions?
    EDIT: Per usual I find my answer a minute after I ask the question, just had to load the family all over again and it seems to work
  1. Labels
    By Dr2430 in forum Architecture and General Revit Questions
    Last Post: April 24th, 2018, 08:21 PM
  2. Sticker/Labels
    By Saldambro in forum MEP - General
    Last Post: February 22nd, 2017, 12:20 AM
  3. Can't get rid of labels
    Last Post: October 12th, 2012, 08:29 PM
  4. Drawn By Labels
    Last Post: August 21st, 2012, 02:27 PM
  5. Stair labels
    By chris.macko in forum Architecture and General Revit Questions
    Last Post: March 16th, 2012, 10:58 PM
