Thread: tags
    December 29, 2014
    Masterton, New Zealand
    16
    08:12 AM
    tags
    I am so very new still to revit and not always sure if it behaves the way it should.
    I have placed some tags on a structural plan but even though I tell it to be horizontal, it comes in diagonally.
    Any idea why?
    I tried space bar and it just flicks it around 90 degrees.
    Regards
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,570
    01:12 PM
    Quote Originally Posted by CAD Services and Design View Post
    Any idea why?
    Regards
    what type of tag and how are you telling it to be horizontal? Is it an OOTB tag or one that you have created??
    December 29, 2014
    16
    08:12 AM
    Hi Dave
    Thanks for the reply. I am only using OOTB command. Hard enough already with just those.
    I am using the tag by category from the QA toolbar and spec horizontal.
    When placing the tag to my steel column it comes in at 45 degrees both on plan and elevations/sections. Spacebar will flick it to Vertical on the QA bar but only a 90 degree rotate on the plan and still at 45 degrees.
    Using the 2019 version which I just installed (NZ version)
    Senior Member alexo4141's Avatar
    May 25, 2011
    Qubec, Canada
    548
    04:12 PM
    If you open the tag family, you should see that the label is set to 45 degrees. Rotate it to be horizontal, save as and load it in your project. Should do the trick.
    December 29, 2014
    16
    08:12 AM
    Thanks Alexo.
    I have had the program for 4 years now but only just start to work with it.
    I have loaded another tag into the file and that has fixed it.
  1. Tags
    Last Post: March 28th, 2018, 08:15 PM
  2. How do you name your tags
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 6th, 2016, 07:37 AM
  3. Tags disappeared - tags size
    By filomenanigro in forum Architecture and General Revit Questions
    Last Post: September 27th, 2015, 01:59 PM
  4. MEP Tags
    By wgfletch in forum MEP - General
    Last Post: April 21st, 2015, 06:03 PM
  5. Default Position of Door Tags (or any tags for that matter):
    Last Post: December 23rd, 2011, 08:45 PM
