Hello,
I have a problem which was already discussed in this forum but there was no answer.
I want to do an area claculation for a house with a lot of dormers. If I use the "dormer opening" tool in the Architecture tab to cut the space out of the roof the room below doesn't fill out the space in the dormer and is not used for area calculation like in the attached picture. The dormer opening itself is still room bounding which it should be not.
Here it is suggested to turn of room bounding of the roof and add room seperation lines, but I don't know how to add room seperation lines and still get the right shape of the roof.
https://www.revitcity.com/forums.php...hread_id=25188
Is there anybody else with the same problem?
Thanks!
