Thread: Air terminal tag - Underline
    August 27, 2018
    02:47 PM
    Question Air terminal tag - Underline
    Hi All!
    Is there any chance to modify the underline thickness in an air terminal tag? Attached a screenshot to understand better.
    2,685
    07:47 AM
    Looks like part of the chosen font. Pick a new font or, if you have the means, reverse engineer it to make the changes you want. Apart from that, use a symbolic line that you can control the length and thickness of.
    August 27, 2018
    02:47 PM
    I have already changed many fonts and nothing changes.
    And the problem with the symbolic lines are, you can not control the length of the line automaticly because there are lots of air terminals and there are different names.
    So sometimes the line is too short and sometimes too long.
    Thanks for your reply.
    1,402
    04:47 PM
    Looks fine to me.
    Why is this necessary and what is the added value of changing it compared to the time and effort it will take to find a work-around to make it different to how revit works?
    (Is the question I would ask my boss if they told me this is something I should care about..)
    Changing the thickness of the leader line is possible, if that helps.
  1. Room Tag: Room Name underline, room number not underline
    By JasonNelson92 in forum Architecture and General Revit Questions
    Last Post: November 17th, 2016, 04:26 PM
  2. Air terminal family
    Last Post: March 6th, 2016, 05:55 PM
  3. Revit OpEd: Text Formatting with Bold and Underline
    Last Post: February 14th, 2015, 04:15 PM
  4. Air terminal family
    Last Post: November 3rd, 2014, 03:19 PM
  5. Air Terminal family
    Last Post: August 5th, 2014, 04:11 PM
