Thread: Range of Values
    February 16, 2012
    4
    02:07 AM
    Range of Values
    I am working on a panel that has a min. and max length. I have been reading and following along on the previous forum posts on the same subject.
    When I load the family into a project and change the length of the panel to be outside of the range allowed, it still allows the inappropriate condition.
    If anyone can help me figure out what I may have done out of order, please let me know.
    I have attached the formula and RFA file.
    Thanks in advance.
Name:	min-max value.JPG
    March 21, 2013
    275
    01:07 AM
    Drive the ref planes with your validated parameter (PWvalid), not the user input parameter (Panel Width). BTW, unless you're doing something with geometry (like graphically showing the possible extents), you shouldn't need the PWmin & PWmax ref planes to control the width.
    February 16, 2012
    4
    02:07 AM
    Such a simple fix.
    Appreciate the ref plane tip. I'm still getting used to formulas. I've only ever had to use Revit "out of the box". Creating families is getting pretty fun.
    Thanks a lot
  1. key-values
    By Ning Zhou in forum Dynamo BIM
    Last Post: February 9th, 2017, 11:27 AM
  2. Predefined values in new sheets
    By Munkholm in forum Third party Add-Ins, API and R&D
    Last Post: December 5th, 2014, 01:42 PM
  3. Complex Calculated Values
    By garebear in forum Structure - General Questions
    Last Post: January 29th, 2014, 04:58 PM
  4. calculating values
    By paudiesf in forum Architecture and General Revit Questions
    Last Post: May 29th, 2012, 12:32 PM
  5. Parameter values
    By bangobeat in forum Out There
    Last Post: October 26th, 2011, 12:27 AM
