Thread: Family error - how can I get around it
    Junior Member Bogey1977's Avatar
    July 12, 2018
    Nederland
    32
    01:00 AM
    Hi all,
    I am building a family for flangs.
    In the family there are 5 flangs (4, 8, 12, 16 and 20 holes). The bigger the flang the more holes.
    Depending on a parameter from the LookupTable the family knows which flang has to be visible and which four has to be invisible.
    The first 2 flangs (4 and 8 holes) went perfect.
    BUT now I am busy with the 12 holes and stumble uppon an issue.
    The small flangs with 4 holes in it, can't hold 12 holes inside (holes will overlap -> error).
    Those flangs who gives the error are not show (they are invisible) but despite that they ar being draw.
    Is there a way to handle this?
    I thought about making the holes very small, but the size of holes come from LookupTable, so I can't change that parameter with a formula.
    The one sollution I can think of, is to add more parameters to the lookuptable, for each flang its own hole size and make the sizes for the other 4 holes very small... I'm quite sure this wil work, but am curious to do this in a different and better way.
    Last edited by Munkholm; September 11th, 2018 at 09:00 AM. Reason: text formatting
    June 21, 2012
    Tours, France
    1,116
    01:00 AM
    Hi Bogey1977, maybe is more easy for all people here if you post some images of the family and screen shots of the error, and if you are agree to share the family with us I'm pretty sure that one of the genius here can help you more easy!! regards
    July 12, 2018
    Nederland
    32
    01:00 AM
    Been busy with this one, am a little further, hope I can make myself clear. Screenshots I guess don't help in here.
    1.) I have 5 different families (flange with 4 holes, 8 holes, 12 holes, 16 holes and 20 holes) the bigger the size the more holes.
    2.) I have 1 parent family with the 5 families from point 1 nested in it.3..) I made a "Family Type" parameter inside the parent.
    2.) I made 5 types inside the parent family.
    3.) For each type I set the "Family Type" parameter to the correct nested family.
    I think above is right and clear to me. But then
    For example:
    size 1, 2, 3 and 4 need type 1
    size 4, 6 and 7 need type 2
    size 8 and 9 need type 3
    size 10, 11 and 12 need type 4
    size 13 needs type 5.
    When parent loaded in project, where do I tell the parent that for size 8 it needs type 3.
    Last edited by Munkholm; September 11th, 2018 at 09:01 AM. Reason: text formatting
    2,777
    09:00 AM
    Quote Originally Posted by Bogey1977 View Post
    if it's an instance, the properties palette. If it's type then type dialogue. Unless I'm missing something?
    assuming you applied the parameter to the nested families and didn't just create the parameter on its own in the family types dialogue?
    1,405
    12:00 AM
    Why not just use a radial array for the holes/bolts?
    Set the number and spacing of the holes based on the flange diameter, using formulas.
    That way you can make one family for any size situation without messing about with Family Type parameters and lookup tables.
    For things that vary in a linear way, use a formula with an 'a=bX + c' (Straight line) relationship. Then you can set b and c to fit any data you have. Like flange outer radius = pipe radius x b + min flange c
    For things that vary with discrete steps, use if statements. If(a>10, 20 holes, if(a>5, 10 holes.... etc.
    Writing it out in notepad with tabs and multiple lines is easier. When you paste in to revit the spaces/lines will be removed.
    Making stuff fully parametric means you only have to manage lots of Types, not lots of separate Families, which is a lot easier.
    July 12, 2018
    Nederland
    32
    01:00 AM
    This is how I was starting whit the family, untill I got the advise to try to avoid using array's and voids, cause array's and void's make the model slower and makes it vulnerable for errors.
    July 12, 2018
    Nederland
    32
    01:00 AM
    I added my familiy's, hope it makes it more clear.
    There has to be looked to the value of NLRS_M_c01_diameter, when value is:
    - below 600, then fam 20 holes has to been show;
    - below 500, then fam 16 holes has to been show;
    - below 355, then fam 12 holes has to been show;
    - below 280, then fam 8 holes has to been show;
    - below 90, then fam 4 holes has to been show;
  1. ERROR - annotation family
    By cganiere in forum Architecture - Family Creation
    Last Post: December 11th, 2015, 06:44 PM
  2. Loading Family Error?
    Last Post: March 20th, 2015, 01:50 PM
  3. Family type error
    By Hoekveen in forum MEP - Family Creation
    Last Post: October 20th, 2014, 01:06 PM
  4. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 11:56 AM
  5. Family placing error
    By bangobeat in forum Architecture - Family Creation
    Last Post: July 25th, 2011, 09:42 PM
