Thread: Printing question
    Junior Member Dude__'s Avatar
    July 13, 2018
    Connecticut
    13
    09:43 PM
    Printing question
    I am trying to print some sample PDF's of the families I created. I also created a titleblock. For some reason the 3D view takes an excruciating long time to print out. Is it because it's shaded? Is there a way I can get it to print correctly yet cut down on the processing time?
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    05:43 PM
    Export the 3D view as an image and place the image on the titleblock perhaps.
    1,614
    03:43 AM
    Is the filesize very large as well after it takes so long to make the PDF?
    If so, I think there should be some setting in your PDF printer that might cause that, like DPI or embedded images.
    July 13, 2018
    Connecticut
    13
    09:43 PM
    I remember in the past we had to do something different when creating a PDF from Revit. That it didn't work very quickly creating a PDF. There was an extra step needed. I don't recall that process though. I have set everything to draft settings, I turned off the far clipping plane, and it is still bogging down and not creating a PDF.
    1,614
    03:43 AM
    Any chance you can use a different PDF printer to see if it is the printer or Revit causing the issue?
    I think I had issues with the Adobe PDF printer giving extremely large files (and taking forever to print).
    July 13, 2018
    Connecticut
    13
    09:43 PM
    I did tune down the DPI a bit to 600. Also, I noticed that I have to do a print preview, then I hit print, from the preview screen, it sends me back to the main print dialogue box, and from there, once I hit print, it works just fine.
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    345
    06:43 PM
    I would decrease the DPI to 300. If the 3-d view has hatches, patterns, or anything overly detailed, the PDF output can take 10-20 minutes. Reducing the DPI from 600 to 300 can reduce the output time down to a fourth of the time.
    February 5, 2012
    51
    01:43 AM
    I had the same issue with a project. When I started exporting and placing images on sheets, the plot time returned to what it was before hand.
  1. Printing to PDF
    Last Post: November 12th, 2014, 03:44 PM
  2. Newbie Question: Good Practices for Model Documentation/Printing
    By colokate in forum Architecture and General Revit Questions
    Last Post: March 3rd, 2014, 06:07 PM
    Last Post: October 21st, 2013, 04:15 AM
  4. 3D printing question
    By mihan in forum Third party Add-Ins, API and R&D
    Last Post: May 22nd, 2013, 07:44 AM
  5. Printing Question
    By SuperDave in forum Architecture and General Revit Questions
    Last Post: May 3rd, 2013, 03:59 PM
