Results 1 to 10 of 10
Thread: Shape handle, dragging grips
    September 23, 2014
    45
    03:36 AM
    When I load a family into the project, I am loosing a grips.
    I lock up a ref planes and I am adding an instance parameters as well.
    What am I doing wrong?
    2,777
    01:36 PM
    'Strong' reference planes should give you stretch grips.
    June 21, 2012
    Tours, France
    1,116
    05:36 AM
    Yes! as @elton already said you just only need to change your reference planes from: Not a reference; For: Strong reference or Ref.Right and Ref.Left references, go to Properties - Other - Is the reference - (and here you need to change the status of your reference) that should do the trick
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    03:36 AM
    I always use weak reference for grips personally.
    December 11, 2013
    464
    03:36 AM
    In fact, that's what the original family has and when I load it into an empty project, it works fine. I'm not seeing the problem.
    September 23, 2014
    45
    03:36 AM
    Thanks for your tips. Yes, I have changed for a strong references and it is working fine in project.When I go the 3D view, then I still do not have those grips-they are in 2D view only.
    I remember, I used to have those grips in 3D view, but I forgot how I did this. Any ideas? Do I have to change anythig else in Properties?Cheers
    June 21, 2012
    Tours, France
    1,116
    05:36 AM
    Yes those grips are visible only in 2d, regards
    11,005
    10:36 PM
    You can get them in 3D if you make the grips with Reference LINES instead of reference planes. John Pierson went over this in his BILT lab.
    Aaron Maller
    Director
    Parallax Team, Inc.
    June 21, 2012
    Tours, France
    1,116
    05:36 AM
    Aaron Maller
    Director
    Parallax Team, Inc.
    WOW this is great thank you Aaron!
    September 23, 2014
    45
    03:36 AM
    Thanks a lot Aaron. I will check it out.
  1. multiple shape handle grips
    By spotless in forum Architecture - Family Creation
    Last Post: July 24th, 2018, 07:43 PM
  2. Can't get Nested Family Shape Handle to show up
    By sarahcaudle in forum MEP - Family Creation
    Last Post: March 17th, 2016, 06:03 PM
  3. Can't get Nested Family Shape Handle to show up
    By sarahcaudle in forum Architecture - Family Creation
    Last Post: March 9th, 2016, 02:59 PM
  4. Dragging views to Sheets
    Last Post: August 18th, 2012, 02:33 AM
  5. Shape Handle placement
    Last Post: May 7th, 2012, 10:09 AM
