Thread: water overflowing gutter at roof intersections
    September 21, 2018
    Gales Ferry, CT
    05:47 PM
    I have a ranch home. Approximately two thirds from one side, I have an entrance way porch with a roof. Thus the porch roof intersects the main roof. there are two gutters. both shaped like an "L" One gathers water from the main roof and one half of the porch roof. the other does the same.
    PROBLEM
    water leaks (gushes) over the gutter at the intersection of the two roofs. One side is considerably worse than the other (must be a hint which I can not decipher).
    The gutter intersection that leaks the most has the longer run to the downspout. that part of the roof also has an overhanging tree.
    I have pitched the gutters. I got rid of the gutter guards and made sure the gutter was clean before a storm. still have the problem.
    I am not sure how high the gutter should be relative to the drip edge.
    I am about to reroof the entire southern facing roof. Now is the time for me to do the gutter shingle thing right. I am planning on redoing the facia and soffit.
    adding 3/4 " cdx to existing roof (to get rid of roof sag between the roof rafters) and placing rubber underlayment under the entire shingled roof.
    I am 73 and need to get the roof in shape for my wife. I do not expect to live out the decade as I have cancer.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    01:47 PM
    I would think whoever you get to re-roof your house will be able to figure this out....are you using Revit to detail everything?
    Member cganiere's Avatar
    January 5, 2011
    218
    02:47 PM
    I think that the problem stems from the water gathering speed. You could install a diverter to slow the water down before it gets to the intersection.
  1. Gutter and Roof planes
    Last Post: September 23rd, 2018, 09:01 AM
  2. Interior gutter and wooden roof
    By fconcas in forum Architecture and General Revit Questions
    Last Post: January 28th, 2017, 10:50 AM
  3. Gutter on non-perpendicular Roof Edge
    By Ben-May in forum Architecture and General Revit Questions
    Last Post: July 24th, 2011, 12:16 PM
  4. Gutter, roof and Friday morning
    Last Post: April 22nd, 2011, 02:15 PM
