Results 1 to 8 of 8
Thread: trying to add a category parameter
    May 10, 2011
    05:28 PM
    Hi, I'm trying to create a structural foundation tag with elevation, that references the top of footing instead of bottom of footing.
    I can create the parameter but it shows as a ? instead of an elevation value, perhaps I am choosing the incorrect "type of parameter"?
    I tried to look for the elevation at bottom parameter, but could not find it. A seperate but likely important consideration is the shared parameter file for RST 2012. I am still struggling with this concept.
    thanks
    bluedog
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,564
    09:28 PM
    You'll need to use a custom shared parameter cause the OOTB isn't useable (as far as I know).
    But then it should work. What did you do exactly? Care to share your family so we can take a look?
    Quick how-to on Shared Parameters here...
    May 10, 2011
    05:28 PM
    Thanks, attached you'll find the tag. All I am really trying to do is have the tag reference the top of the footing instead of the bottom.
    The OOTB tag refernces the bottom.
    I created the "elevation at the top parameter and attached it to the label, but all that shows up is a "?".
    thanks
    3,231
    05:28 PM
    I don't think this is possible in a BIM-like way. Only by manual input. The closest you can get is to show the elevation at bottom, and the thickness of the footing. Let the reader of the drawing do the math, if necessary.
    Last edited by Alfredo Medina; September 22nd, 2011 at 02:56 PM. Reason: Updated image
    May 10, 2011
    05:28 PM
    What I usually do is tag the footing and then use the spot elevation to identify the top of footing height. This is our standard.
    That works but it takes to long.
    Revit has one that does the bottom (see attached). I thought it would be a simple procedure to make a new category parameter that read the top of footing instead bottom of footing.
    If I knew what the "type of parameter" (number, length, etc) it should be, it might work. Or maybe it's not that simple.
    thanks
    3,231
    05:28 PM
    Quote Originally Posted by Bluedog View Post
    ...If I knew what the "type of parameter" (number, length, etc) it should be, it might work. Or maybe it's not that simple.
    No, it's not that simple. You can know the name of the reference level, but Revit does not let you get the elevation value of that level, and you cannot tag a calculated value such as level - thickness. It can be done with manual input, but that's not the idea, because then you are in risk or showing wrong information in the tags if something changes in regards to the elevation of the footings.
    Senior Member alexo4141's Avatar
    May 25, 2011
    Qubec, Canada
    548
    05:28 PM
    I know that it doesn't fit with your office standards but you should try to make a schedule where you can make a calculated parameter : El. Top = El. Bottom + Thickness. [Saw something about thickness issues, maybe you are more safe with eLEl. Bottom + (Volume/(Width*Length)]
    Regroup in Mark and it replaces your tag and is you get more space for others informations...
    Just my thoughts
    Alex
  1. In-Place Family Parameter in Multi-Category Schedule?
    By narlee in forum Architecture and General Revit Questions
    Last Post: August 25th, 2011, 09:22 PM
  2. Red lights; what category?
    By Gordon Price in forum MEP - General
    Last Post: June 13th, 2011, 01:29 PM
  3. Which category does it belong to?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: June 1st, 2011, 11:24 AM
  4. Shared Parameter Category
    By Drew in forum Architecture and General Revit Questions
    Last Post: May 24th, 2011, 11:39 AM
  5. Convert Project Parameter to Shared Parameter
    By Rustle in forum Architecture and General Revit Questions
    Last Post: January 5th, 2011, 07:35 AM
