Thread: how to create a curve elevation in massing?
    July 26, 2018
    24
    10:04 AM
    Hi!! I'm trying conceptual massing like for the first time & I need a little help!! I'm trying to make the form that is attached in picture. I'm trying to achieve the curve profile of building. Can someone help me considering this is an emergency.??
Name:	WhatsApp Image 2018-10-08 at 9.24.39 AM (1).jpeg
ID:	34879   Click image for larger version.
Name:	WhatsApp Image 2018-10-08 at 9.24.39 AM.jpeg
    3,231
    01:04 AM
    I see that your question has been without an answer for more than a month, so, this information comes too late for you. But anyway,...
    1) Bring your sketch as an image to an elevation view in the generic adaptive template (or in the mass template if you are interested in creating mass floors and schedules).
    2) In the elevation view, scale the image. You can use that human figure that you drew, as a reference for the scale.
    3) Draw reference lines or splines tracing over the image, to form those closed shapes that you see on the second image.
    4) Select those shapes, and do Create Form. Add other elements as necessary, voids if required, etc.
    5) Load the family into a project, and convert faces to walls, floors, roofs, etc.
    3,231
    01:04 AM
    Quote Originally Posted by aditya_31 View Post
    Same query here
    See post #2.
  1. Without massing in Revit LT how does one create sloping walls?
    By Roberto in forum Architecture and General Revit Questions
    Last Post: November 13th, 2013, 08:18 PM
  2. how to create required railing design or massing using a reference raster image ?
    By bhavukjain in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 6th, 2013, 04:20 AM
  3. create elevation views?
    By dsec123 in forum Architecture and General Revit Questions
    Last Post: September 17th, 2012, 11:08 PM
  4. Is it possible to create a smooth closed curve with adaptive points?
    By aksrocks in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 27th, 2012, 10:43 AM
  5. Need help to create curve roof! Urgent!
    By melcas in forum Architecture and General Revit Questions
    Last Post: December 30th, 2011, 07:22 PM
