Thread: Curtain Wall - customised curvy mullion
    April 12, 2015
    63
    08:51 PM
    Hi. I'd like to know if it's possible to customize the curtain mullions to be something similar to S shape profile in section. I have some window grilles (very long stretch) which need this. I have a railing family of it. But it cannot be embedded in wall, so i ended with a bottom wall and top wall.
    Thanks in advance.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,549
    12:51 PM
    Quote Originally Posted by tiangtiang View Post
    Thanks in advance.
    curtain wall mullions can be created in any shape you like as long as the profiles are closed regions. The issue would be, how would this S shaped mullion deal with intersections with perpendicular sections? Can you post a screen shot of what you are trying to achieve?
    April 12, 2015
    63
    08:51 PM
    not S-shape exactly...but this is what I want as a curtainwall, I only have it in railing family, it's not able to embed in a wall and cut away the wall.
    2,714
    06:51 AM
    If your dedicated to using curtainwall, I would create those balusters as a curtain panel, you won't get millions to sweep like that.
    Imho you're going to hit more roadblocks doing this with curtain walls than railings.
    Any reason you can't stick with railings as that is obviously what it is?
  1. Cannot add mullion in curtain wall grid
    Last Post: January 9th, 2019, 05:33 PM
  2. Curtain Wall Mullion Parameters
    By Noam_r in forum Architecture - Family Creation
    Last Post: May 31st, 2018, 04:31 PM
  3. Curtain Wall Mullion Mitering
    Last Post: April 17th, 2015, 12:40 AM
  4. Curtain wall mullion
    Last Post: July 15th, 2014, 02:22 PM
  5. Curtain Wall Mullion Takeoffs
    Last Post: August 6th, 2012, 08:11 PM
