Thread: Curtain wall does not show right in IFC- Profiled curtain wall
    January 27, 2017
    48
    03:17 PM
    Hello everybody,
    I am battling with a bit of a problem.
    I have a facade consisting heavily of profiled / attached to top curtain walls.
    Whenever we make an IFC Export, the model shows very blocky in Solibri, chopping off the "profiling" and instead creating straight "stair like" edges.
    (please take a look at the attached images).
    I have tried all the IFC settings including different Levels of Detail for the export and same result, as well as exporting from both the german and the english revit versions.
    Googling the problem hasn't been very productive, and I could not find anything similar.
    Any ideas would be greatly appreciated!
    Greetings,
    Snuffy
ID:	35019   Click image for larger version.
    January 27, 2017
    48
    03:17 PM
    bumpidy bump?
    July 26, 2017
    03:17 PM
    Hey! I am facing the same problem. I tried all IFC settings, but still no luck. Maybe someone else found a solution?
    Many thanks!
    Edit: So if anyone is interested: you have to use the system panel to get the correct ifc export. just duplicate the glazing panel and give it the necessary properties.
    1,628
    05:17 PM
    Are you using the latest IFC exporter?
    Both a Curtain Wall and a normal wall work OK for me when exporting to IFC
Name:	IFC export.PNG
    3,313
    10:17 AM
    Nice branding, Robin!
    1,628
    05:17 PM
    2 birds with 1 stone, it is my project basepoint as well
    And with some clients not wanting my logo on the sheets for some reason, it is a good way to sneak my website in there for all the other BIM people involved at least
    January 27, 2017
    48
    03:17 PM
    I have tried both of your solutions @Robin and @Aleqx.
    Robin, yours works just fine, as long as you use a standard wall and standard mullions from Revit. As soon as you replace the PANELS themselves with let's say...a wall, it's the end of the line.
    Aleqx, Could you please elaborate on what to do with system families? In the images I have used only system families, added facade grids to them, then replaced the empty "glass" panels with walls.
    1,628
    05:17 PM
    AH, yes with a wall replacing the CP it goes weird.
    I think what Aleqx means is that you do not replace them with a wall, but make a new Curtain Panel (copy the standard Glazed panel) and give that the right properties for your purpose.
  1. Going from System Curtain Wall to a curtain panel on non orthogonal glazing
    By ArchitectChris in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2018, 10:21 AM
  2. Using a Curtain Wall type as a panel nested in a different type of curtain wall
    By itisntmakingsense in forum Architecture and General Revit Questions
    Last Post: December 12th, 2016, 10:09 PM
  3. Custom Curtain Panel not responding to Curtain Wall Extents
    By kas9du in forum Architecture and General Revit Questions
    Last Post: June 24th, 2015, 02:30 PM
  4. Problem with adding custom curtain wall panels to curved curtain wall.
    Last Post: November 20th, 2013, 06:16 PM
  5. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    Last Post: June 14th, 2012, 02:45 PM
