Thread: .rvt to .max a Revi(si)t
    4,442
    01:28 AM
    Just been having it out with our Viz. people - who, I trust, but reckon might be missing a trick - as they're adamant there's still "a whole lot of work to be done" to get our .rvt in (and out of) .max...
    So,
    1) .rvt = linked, material swap-outs are assigned, link gets updated, what's the problem?
    2) .fbx = as above?
    3) .dwg = all appropriate Revit categories get exported to appropriate layers, file is linked into 3DS by material... swaps are made once, 3DS maintains link = simples?
    Okay so I'm probably being unfair - but that's what I the blogs and stuff online seem to infer...
    So (short of composition, population, post-production, etc) what might be taking so long - to get from export to (rendered) output, given we use a fairly consistent palette of materials?
    Junior Member skisouth's Avatar
    Here
    27
    07:28 PM
    The problem I've had with the Revit direct link was the normals were random in Max. If you fixed them, then reloaded - yep - normals wrong again.
    At the time, I was under a deadline, so I switched back to Fbx. To me, FBX is quite easy and reliable for the most part. I have a few issues with 2019, but I haven't had a chance to test the 2019.1 edition at any length to see if it is resolved.
    Forum Addict willsud's Avatar
    December 13, 2010
    Ambleside, Lake District, UK
    1,081
    01:28 AM
    I prefer FBX but if your viz. people are using 2019 version do you know what rendering engine they are using? I've given up 3dsMax for the moment since they removed Mental Ray from 2019 as Enscape and Lumion are a bit easier, although I find their renders over-anti-aliased compared to 3dsMax.
    4,442
    01:28 AM
    V-Ray.
    (how much) Does the render engine determine the workflow?
    One understood one associated one (Revit) imported material "A" with another, preferred (3DS) material, and et voila? No?!?
    December 13, 2010
    1,081
    01:28 AM
    Only if you haven't yet got a workflow with the materials and renderer I would have thought.
    I was never clever enough to just swap out sets of materials, although I've read somewhere that is possible.
    Last Post: November 15th, 2016, 10:15 PM
  2. Revi 2014 API parameters
    By James in forum Third party Add-Ins, API and R&D
    Last Post: December 18th, 2015, 12:34 AM
    Last Post: November 24th, 2015, 10:15 PM
  4. Replies: 0
    Last Post: April 27th, 2013, 01:16 PM
    Last Post: March 13th, 2012, 11:45 PM
