Thread: Simple Electrical symbols, no 3d required..1:100 or 1:50
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    884
    07:40 AM
    I'm a bit puzzled about something that is probably very simple for most of you. And might well have different approaches.
    If I were to require simple electrical symbols without any modelled item attached and i want to put these on plans of either 1:100 or 1:50 what would be the most efficient category template to create these in? And also use them in some form of legend on the same sheet.
    Initially I'm thinking detail items.
    February 5, 2012
    51
    08:40 PM
    Remember that the OOTB content uses embedded generic annotations for the plan symbology so that it scales, etc. You could go ahead and construct them as GA so that they scale and you have a great start if you ever go full 3D.
    Member Marcel Jansen's Avatar
    December 26, 2011
    The Netherlands
    241
    09:40 PM
    I would still use 3D objects, and use filters to make them visible in the views you want.
    June 21, 2012
    Tours, France
    1,102
    09:40 PM
    I use 3D models created in "Electrical Category" with a nested "Detail element" which I only want to see in my electrical plans, this way I can control visibiity and 3D representation, also you can schedule those elec item easily, so I think this can be a good approach, regards
    June 21, 2012
    Tours, France
    1,102
    09:40 PM
    Quote Originally Posted by mjajansen View Post
    Yes, that is a very good approach, I use the same method as you've described
    June 13, 2011
    Australia
    884
    07:40 AM
    Thanks guys.
    Last Post: July 20th, 2017, 05:00 PM
  2. Embedded Electrical Annotation Symbols
    By RobDraw in forum MEP - Family Creation
    Last Post: May 12th, 2017, 06:59 PM
  3. Electrical architectural symbols, accepted graphics and method?
    By biff in forum Architecture and General Revit Questions
    Last Post: December 26th, 2016, 09:35 PM
  4. Replies: 15
    Last Post: May 15th, 2014, 03:53 PM
  5. Electrical symbols & Generic Annotations
    Last Post: June 12th, 2012, 05:50 PM
