Thread: adjust titleblock revision schedule row height
    July 20, 2011
    854
    05:40 PM
    i thought it's automatic but seems not the case, forgot how to do it, can anyone point me to right direction? thanks
    January 19, 2012
    345
    06:40 PM
    Select the Schedule in the PB, then in the Properties Palette go to Appearance Tab, The Height setting....swap that.
    1,509
    01:40 AM
    I think it is controlled by the text height in the table in your titleblock family.
    July 20, 2011
    854
    05:40 PM
    that's what i thought, as long as text height changed, all rows will change automatically (not just 1st row w/ text), in fact, it's the case when i created titleblocks for A0 and A1, somehow it's not working for A2, etc.
    edit: OK, figured out, it's the body text need to change height, thanks all
    1,509
    01:40 AM
    So maybe the option cfrevizo mentions is set the wrong way for that titleblock?
    And aren't you just copying the A1 and changing dimensions for the A2 titleblock?
    Or even have 1 titleblock family for all the sizes?
    July 20, 2011
    854
    05:40 PM
    thanks Robin and cfrevizo, i need to change body text height instead of just title/header.
    well, we create separate TBs for metric A0 ~ A4, and imperial A ~ E, sounds crazy or better way? is 1 TB for all sizes really work?
    1,509
    01:40 AM
    yeah the body text, that sounds logical .
    I have one for A2, A1 and A0 but also for extended sizes (large formats) and 1 for A3 and A4 (small formats) because those look very different for me.
    So just 2 families with a few types. I think it is easier to manage having them as 1 family instead of having one for each size.
  1. Revit MEP copy revision schedule to different titleblock
    By baggins79 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2018, 08:54 AM
  2. Adjust Tag Leader Height Origin
    By SamHenderson27 in forum Tutorials, Tips & Tricks
    Last Post: December 1st, 2015, 07:40 PM
  3. Titleblock revision
    By alijack in forum Architecture and General Revit Questions
    Last Post: March 31st, 2014, 01:58 PM
  4. revision clouds in legend views do not generate revision schedule entries
    Last Post: July 1st, 2013, 11:39 PM
  5. Tekeningenlijst/schedule van sheets met revision schedule
    By rijber in forum Nederlands forum
    Last Post: February 2nd, 2013, 02:50 PM
