Thread: Sheet Issue Date parameter
    December 2, 2018
    8
    06:47 AM
    Hello,
    Is there anyway to make this "sheet Issue Date" parameter to show month in a written form as in the picture that I attached. The problem is that after I create new sheets in the project, I have to write month manually. It would be great if someone knows how to make it automatically update.
    3,194
    12:47 AM
    It is possible to add a Time/Date stamp to you Titleblock family, but it may not be what you're looking for
    See here:
    https://knowledge.autodesk.com/suppo...ate-time-stamp
    This parameter updates itself when the Sheet is printed. If you're looking for a "Date Issued", you will have to type that in yourself.
    As far as the formatting goes, not a lot of options there, either. It always uses whatever format you have your computer (Windows) date format set to.
    Please vote up my idea to add the badly needed true Date parameter to Revit:
    https://forums.autodesk.com/t5/revit.../idi-p/6323051
    December 2, 2018
    8
    06:47 AM
    Thanks Dave,
    At least I can choose several sheets in one step and change their " Date Issued" manually makes it a bit faster.
    Wellington, New Zealand
    705
    07:47 PM
    I tend to use the revision Issue date now instead: too may times the manual input to all the sheets of the issue date is not done systematically, but people tend to ensure the revision, and revision date is filled out correctly.
  1. Replies: 4
    Last Post: May 4th, 2018, 12:02 AM
  2. Sheet list - How can I add a circle or dot parameter relating sheet names to phases?
    By yral87 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2015, 08:48 PM
  3. issue date on title block
    Last Post: March 22nd, 2013, 05:47 PM
  4. Finding the date a sheet or view was last worked on...possible?
    By chong in forum Architecture and General Revit Questions
    Last Post: April 16th, 2012, 06:44 PM
