Results 1 to 10 of 14
Thread: Attempting my first Python Node, need some basic help
    February 22, 2013
    367
    05:57 PM
    I'm trying to make a Dynamo script that will, among other things, take an electrical circuit's current in amps and spit out a breaker size. I need to do a nested if statement and it would be a bear to construct graphically with nodes. If this were a Revit Family, I'd type a long but simple nested conditional formula like this into the "Circuit Breaker Rating" parameter, something like:
    if(Apparent Current < 15, 15, if(Apparent Current < 20, 20, if(Apparent Current <25, 25...)) ... on up to 150 amps.
    How would I accomplish this in a Python Node? Here's what I've got so far but Dynamo is giving me the error "IrongPythonEvaluator.EvaluateIronPythonScript operation failed. undindent does not match any outer indentation level." I'm sure I'm making some basic syntax mistakes here and I'm hoping that someone can help me out.
    import clr
    clr.AddReference('ProtoGeometry')
    from Autodesk.DesignScript.Geometry import *
    #The inputs to this node will be stored as a list in the IN variables.
    dataEnteringNode = IN
    if IN < 15:
    b = 15
    print(b)
    else:
    if IN < 20:
    b = 20
    print(b)
    else:
    if IN < 25:
    b = 25
    print(b)
    else:
    if IN < 30:
    b = 30
    print(b)
    #Assign your output to the OUT variable.
    OUT = b
    Any help would be appreciated! I have a rare slow day at work today and would love to get this Dynamo graph working!
    Member johnp's Avatar
    March 24, 2015
    175
    04:57 PM
    I don't think print is going to work in Dynamo, but I could be wrong.
    This seems to work,
    Code:
    import clr
    result = []
    input = IN[0]
    if input < 15:
        result = 15
    elif input < 20:
        result = 20
    elif input < 25:
        result = 25
    elif input < 30:
        result = 30
    OUT = result
    I am betting there are better ways to do it as well, but those are beyond me.
    February 22, 2013
    367
    05:57 PM
    Exactly what I needed! Thank you!
    I'm a mechanical guy but I recently discovered that my electrical coworkers have been spending a lot of time on manual data entry in their panel schedules: wire sizing, breaker sizing, load names, they've been entering all of this stuff in manually for years and I've never known. So I've started creating this Dynamo script that will fill it all out for them.
    February 22, 2013
    367
    05:57 PM
    One more question...
    Okay, so I have my crude script written and it works, on up to to 500 amps. But now I want it to work on every object in a list input. I want to feed it the Apparent Current of every circuit in the model and have it spit out a list of breaker sizes. I wish there was a "lacing" option for this Python script node.
    It seems like this script only wants a single input and not a list. Is there something I have to write into the Python script to get it to accept a list input?
Name:	Dynamo Breaker Sizing.JPG
    March 24, 2015
    175
    04:57 PM
    To work with a list you need to iterate over it with a "for" statement. Along with this comes the need to append to the output. The modified code below should help.
    Code:
    import clr
    result = []
    input = IN[0]
    for i in input:
        if i < 15:
            result.append(15)
        elif i < 20:
            result.append(20)
        elif i < 25:
            result.append(25)
        elif i < 30:
            result.append(30)
    OUT = result
    February 22, 2013
    367
    05:57 PM
    Thank you! I'll file this away for the future.
    What I ended up doing (before I saw your reply) was to create a custom node with the nested if statement contained in a code block. The code block can't be laced but a custom node can!
    March 24, 2015
    175
    04:57 PM
    Very nice! The first time I used lists I did that as well.
    1,405
    11:57 PM
    .. my electrical coworkers have been spending a lot of time on manual data entry
    Exactly my experience too! They say things like "Revit doesnt have much to offer for electrical, you can only model cable trays" but electrical systems are so much more logical in their structure and data than mechanical. Even using none of the electrical calcs in Revit and only Types and parameters, it would be so much better for handling their design information...
    Im deliberately avoiding Electrical as I have enough to do with Mechanical, waiting for one of theirs to show an interest or learn dynamo...
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    355
    11:57 PM
    All the kudo's for solving it in Python, but as you are describing your problem it's a rounding problem, right? Round up to 15, and then up to the nearest 5.
    Sorry if I misunderstood the original problem.
    February 22, 2013
    367
    05:57 PM
    It's trickier than that, because US standard breaker sizes are 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600, 700, 800, 1000, 1200, 1600, 2000, 2500, 3000, 4000, 5000, and 6000.
  1. Revit Error When Attempting to make view title multi-line
    Last Post: July 18th, 2018, 05:22 PM
  2. Replies: 8
    Last Post: April 30th, 2018, 06:00 PM
  3. Amateur attempting to create family title blocks
    By Branston in forum Architecture - Family Creation
    Last Post: January 31st, 2017, 12:21 AM
  4. Basic Rain Screen for a Basic Revit User
    By tyarndt94 in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2016, 02:37 AM
  5. attempting a waffle slab
    Last Post: January 20th, 2012, 06:00 PM
