Results 1 to 1 of 1
Thread: Type or namespace name "Autodesk" could not be found(Problem at SDK sample compiling)
    November 13, 2018
    6
    07:42 AM
    Exclamation Type or namespace name "Autodesk" could not be found(Problem at SDK sample compiling)
    Hallo, everyone, I am Nan
    I have downloaded REVIT_2019_SDK.msi from https://www.autodesk.com/developer-n...nologies/revit
    After successfully downloading and installing SDK 2019, I tried to compile the samples in the SDK files(See figure 2).
    C:\Revit 2019 SDK\Samples\AllViews\CSz\AllViews.csproj
    The version of my visual studio is 2017. I have installed both .Net framework 4.7 and .Net framework 4.7.1
    The way I installed .Net framework 4.7 and .Net framework 4.7.1 were as follows:
    1: NDP47-DevPack-KB3186612-ENU.exe (see figure 9) for .Net framework 4.7
    2: NDP47-KB3186497-x86-x64-AllOS-ENU.exe (see figure 9) for .Net framework 4.7
    3: NDP471-DevPack-ENU.exe for .Net framework 4.7.1
    4: NDP471-KB4033344-Web.exe for .Net framework 4.7.1, it doesn't work, it says it is because .Net framework 4.7 is already installed
    Ok, after the pre-work, I clicked "build solution ", a lot of errors happened as the main error is (see figure 5 and 6),
    Error CS0246 The type or namespace name 'Autodesk' could not be found (are you missing a using directive or an assembly reference?) ExternalResourceDBServer C:\Revit 2019 SDK\Samples\ExternalResourceServer\ExternalResourc eDBServer\CS\Application.cs 29
    I have tried the .Net framework 4.7 (figure 7) and there is no problem in reference (figure 8)
    I do not know where is the problem. Can anyone help me about this?
    Thank you very much in advance!
    Best wishes
    Nan Zhu
ID:	35289   Click image for larger version.
ID:	35288   Click image for larger version.
ID:	35290   Click image for larger version.
ID:	35291   Click image for larger version.
ID:	35293   Click image for larger version.
ID:	35294   Click image for larger version.
ID:	35295   Click image for larger version.
ID:	35296   Click image for larger version.
  1. "No parameter found by that name"
    By ryntau in forum Dynamo BIM
    Last Post: December 11th, 2018, 09:19 PM
  2. No "Model" type patterns found.
    By anywho in forum Architecture and General Revit Questions
    Last Post: October 14th, 2016, 09:28 PM
  3. Error "No circuit errors found" when deleting objects
    By alnjxn in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2013, 04:47 PM
    Last Post: February 14th, 2013, 03:45 AM
  5. RFO Blog: "Can you provide us with a sample file"
    By RFO Blog in forum Blog Feeds
    Last Post: April 1st, 2012, 09:15 PM
