Thread: Window Brickmould: Nested Face Based Families Not Cutting
    6,329
    04:42 PM
    I'm having an issue getting my brickmould to cut properly once I'm in a project and I can't figure out why. I pulled up my old windows (c. 2017) and everything cuts correctly, but the new windows don't... The brickmould family is built the same way (I'm pretty sure it was a save-as & cleanup) so I can't figure out why one cuts appropriately and the other doesn't. Any insights into why one works as expected and the other doesn't would be appreciated.
    Project file with a dumbed down version of the new window and one of the old windows attached.
    6,329
    04:42 PM
    le bump.
    10characters
    6,329
    04:42 PM
    And I poked blindly at it long enough and got things working
    Extended the void so it cut the face, then pulled it back to be flush with the face. For some reason this doesn't give an error about not cutting, which results in everything working in the project environment.
  1. Void cutting nested families
    By dan_p87 in forum Architecture - Family Creation
    Last Post: October 18th, 2013, 05:10 PM
  2. Louver - Better to be a Window Family or a Face Based Generic Model??
    Last Post: September 19th, 2012, 03:04 PM
  3. Proxy face in Face Based families - delete it?
    By Gordon Price in forum Architecture - Family Creation
    Last Post: February 5th, 2012, 08:07 PM
  4. Face Based VS Wall Based VS Non-Host with Void Families
    Last Post: December 16th, 2011, 04:20 PM
  5. Face-based family cutting two walls at a corner
    By hroark in forum Architecture - Family Creation
    Last Post: December 28th, 2010, 03:43 PM
