Thread: material tag ?
    March 14, 2016
    55
    09:56 AM
    material tag ?
    I am trying to create material schedule with material tag. I am having trouble trying to tag non element with material tag example reveal, model line etc. Is there any way that you can tag non elements with materail tag?
    1,628
    04:56 PM
    A model line does not have a material, so a material tag is not going to be able to tag that. Same goes for a reveal, that's basically just empty space, so does not have a material.
    January 12, 2011
    London, UK
    575
    03:56 PM
    Quote Originally Posted by Hoangtin View Post
    I am having trouble trying to tag non element with material tag example reveal, model line etc. Is there any way that you can tag non elements with material tag?
    Hey Hoangtin, to follow on from Robin's post, it appears as if you're drawing in a CAD fashion . . . with lines, etc.
    You have two ways to work in Revit:
    1. With the model, and you input the data into the elements, such as finishes and other parameters. The tag then just displays the previously input data, such that a wall with a brick material, that ALREADY has a brick material parameter associated with the wall, will get tagged and the tag will display the material, just 'data mining' whats there, in this case 'brick'.
    2. In drafting views. In this case, you can make detail components and assign parameters to them too. But you may need custom tags to 'mine' the data you've input.
    In both cases, you can use keynotes for a previously input list of data that can be used as a text note pointing to an an element and is not data-mining 3D or 2D detail components, if you don't want. See more at this link:
    https://knowledge.autodesk.com/suppo...B8590-htm.html
  1. Wall material display - Fill vs Material pattern
    By ncowherd in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 03:39 PM
  2. Quantities or Material Takeoff, material costs and thermal values
    By alfakappa in forum Architecture - Family Creation
    Last Post: August 22nd, 2014, 10:34 AM
  3. Can't find site material (grass) in material list in Revit 2014
    By Tony Phillips in forum Architecture and General Revit Questions
    Last Post: August 29th, 2013, 04:01 AM
  4. get Ramp material info. for material takeoff purpose
    Last Post: April 15th, 2013, 07:02 AM
  5. Where i can find reflection of material inside material editor ?
    Last Post: November 6th, 2011, 09:21 AM
