Thread: Parametric Lug Chain Family Need Help
    February 18, 2014
    10
    05:14 PM
    What is the best way to make this lug chain.
    Want to be able to change lug spacing and lug quantity to drive it.
Name:	Lug Chain.PNG
    August 19, 2011
    New Hampshire
    511
    08:14 PM
    What is the end goal for this? Does the family actually need this level of control visibly, rather than data driven?
    February 18, 2014
    10
    05:14 PM
    End result is to be able to change the length of my lug table based on lug count and spacing. some math.
    my problem is getting a family of the lug chain itself that has the lugs patterned all the way around like i want.
    tried adaptive and pattern families but i can not place them in my main generic family.
    See uploaded pic of lug table and lug chain(static).
Name:	Lug Chain-1.PNG
ID:	35650   Click image for larger version.
Name:	lug table.PNG
    3,224
    08:14 PM
    In generic families its not possible to repeat an element along a path that contains straight lines and curves, going up and down like that, with count and spacing controlled by parameters. That repetition needs to be done in an adaptive template.
  1. Creation of parametric window family
    Last Post: October 22nd, 2018, 03:03 PM
  2. Parametric family
    By Demeter in forum Architecture - Family Creation
    Last Post: February 13th, 2018, 08:02 AM
  3. Family Array Parametric Basics
    By williamcm in forum Architecture - Family Creation
    Last Post: May 19th, 2017, 10:18 PM
  4. Parametric 2d family with materials
    By C.WILSON20 in forum Architecture - Family Creation
    Last Post: November 20th, 2013, 05:32 PM
  5. Parametric Family Problem
    By Fenners in forum MEP - Family Creation
    Last Post: September 12th, 2012, 08:47 AM
