Results 1 to 10 of 12
Thread: room tag with occupancy info (2019)
    June 26, 2014
    97
    01:32 PM
    wondering if anyone has created a room tag that shows the occupancy info i.e. occupancy group, occupancy load factor(area per occupant), occupant load calculated?
    1,509
    09:32 PM
    Nope, but I think that's just a few Shared Parameters to add to your tag and rooms
    10,787
    02:32 PM
    Unless you want to use Dynamo or an App (or a schedule where you manually translate them), you are better off with a tag that has Name and Number, and then a schedule (that you put on the sheet) with all the Occupancy Calcs. Reason being then that schedule can actually DO all the occupancy calcs for you. (Take the OLF, apply it to the SF, come up with OCC, round accordingly, generate plumbing fixture requirements based on that, and so on).
    As of 2017 or 2018, you can actually build all those calculations in to the TAG itself, but thats completely stupid because then its not in the model itself.
    Member tidalwave1's Avatar
    Las Vegas
    138
    12:32 PM
    not a room tag but an area tag. had to use dynamo and create a schedule.
    June 26, 2014
    97
    01:32 PM
    attached is a project that we have a schedule with what seems to be the appropriate parameters. if someone can tell me what i am missing.
    3,226
    03:32 PM
    Please be more specific. Its not clear what you are asking. The project file does not contain any model elements yet and no custom room tag. I see some schedules showing some occupancy-related information.
    September 12, 2011
    12:32 PM
    Relatively new to Revit. Regarding that you think its inappropriate to calculate occupant load in a tag as its "...not in the model itself..." Is not the schedule also 'outside' of the model? Thanks.
    10,787
    02:32 PM
    I dont think its *inappropriate,* i just think it wont work NEARLY as well. The schedule is MUCH better.
    3,194
    02:32 PM
    The biggest problem with putting your calculations in the Tag is the that's where they remain - in the Individual Tag.
    You can't do anything else with them.
    If you have the information in a Schedule, you can do things with that information in aggregate - calculate totals, for example.
    There are some games you have to play to use a calculated value, but it it possible.
    If the calculation is in the Tag, you have no hope of using it in conjunction with another Room or Area.
    2,732
    01:32 PM
    You can, however, have it in both provided any changes to one you make in the other. For a straight Area/Occupant Load Factor maybe this isn't a big deal (although you do have to decide how you're going to deal with rounding and how to deal with fixed seating but that's true regardless of the route you take) but for other calculations, like plumbing, you quite literally can't do it in the tag.
  1. R&D BIM IoT Occupancy Comfort Sensor
    By m.p.diker in forum Third party Add-Ins, API and R&D
    Last Post: October 20th, 2014, 02:33 PM
  2. Occupancy Label Instance Text Parameter
    By DC1986 in forum Architecture - Family Creation
    Last Post: June 19th, 2014, 09:02 PM
  3. Model Text Using Room Info?
    By jhenry58 in forum Architecture - Family Creation
    Last Post: May 20th, 2014, 04:46 AM
  4. Sticky Notes: Calculate Occupancy Load
    Last Post: January 29th, 2012, 02:18 PM
  5. Revit OpEd: Occupancy Data Application
    Last Post: January 27th, 2012, 06:15 PM
