Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Rough opening for storefront and curtain wall
    March 14, 2016
    55
    08:00 PM
    Can anyone tell if you can custom storefront and curtain wall with a rough opening gap that you can adjust? Currently storefront and curtain wall are model from frame to frame no rough opening spaces.
    10,800
    07:00 PM
    Yes, you can. Ours are built that way.
    2,742
    06:00 PM
    Do you build them into your million profile or is it its own mullion?
    I believe Dave Jones does the latter. Ive been doing the former but am thinking about switching it up.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,550
    05:00 PM
    Do you build them into your million profile or is it it’s own mullion?
    I believe Dave Jones does the latter. I’ve been doing the former but am thinking about switching it up.
    Actually, I use a separate GM family with parametric joint sizes on four sides and width and height dimensions. Since my building backgrounds are always Arch model links I don't want to dimension to linked geometry so my RO frame provides geometry in my model to dimension to. I also often run into situations where the caulking joint sizes at the top, bottom, and sides will be different due to seismic requirements, story drift, etc.
    The GM family consists of lines and overlaid hidden lines and the lines have a yes/no parameter to turn them off. This way I can hide the RO frame but not lose the dimensions associated with it.
    Oh, and all of this is past tense as I am now retired
    10,800
    07:00 PM
    Mine are part of the Mullion (But parametric, so if you need different values its just another mullion type) so it doesnt need another mullion, and you can dimension to mine as well.
    March 14, 2016
    55
    08:00 PM
    So you custom end mullion to show rough opening gap. How did you do that. Any video or instruction how to do that.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    05:00 PM
    More time to prep for curtain wall classes at BiLT and AU...
    May 18, 2011
    Calgary, AB
    431
    06:00 PM
    Quote Originally Posted by Hoangtin View Post
    I do mine similar to Aaron's. You end up with a about 11 profiles to cover off different conditions you'd encounter doing curtain wall.
    If you look at the image, you can see that the profile extends to include the rough opening. Then there is a detail component to provide the innards.
    10,800
    07:00 PM
    Quote Originally Posted by cheinaranta View Post
    This. Except my Profile lines are also split at that reference plane, which create an edge you can Dimension to, should you want to. The Detail Component even has a masking region that protrudes proud of the surace of the wall, to hide the Mullions modeled edge.
    2,742
    06:00 PM
    Mine goes a step further showing the sealants as half ellipses that you can push into the frame should you desire.
    Kinda nutty... probably not worth it.
  1. Curtain Wall Storefront Wall - Custom mullions join issue
    Last Post: November 29th, 2018, 08:51 PM
  2. Editing storefront curtain wall
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: March 7th, 2016, 06:25 PM
  3. Curtain Wall - Storefront - Mullions resetting
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: August 5th, 2015, 05:46 PM
  4. Two-Three Windows - One Rough Opening
    By Craig.Donison in forum Architecture - Family Creation
    Last Post: November 15th, 2012, 04:10 PM
  5. Door & Window Rough Opening parameters
    By Gordon Price in forum Architecture - Family Creation
    Last Post: December 11th, 2011, 10:03 PM
