Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Width of Properties and Project Browser keeps changing
    July 7, 2017
    Hernando, MS
    560
    01:30 AM
    I've noticed recently in 2019.2 that the width of my Properties Palette and Project Browser sometimes changes on its own when projects are opened. I usually have them both docked on the left side, with the edge between the PB and drawing window more or less under the Ceiling button on the Architecture tab. If I close the project and then open another project, the sizes of the PB and PP grow a little more, and more and more each time a new project is opened. At one point today I noticed the PB and PP taking up over 1/3 of my screen width!
    Is anyone else seeing this behavior?
    July 7, 2017
    Hernando, MS
    560
    01:30 AM
    Screen shots of different files opened 6 consecutive times, showing how the toolbar width steadily increases each time.
ID:	35711   Click image for larger version.
ID:	35712   Click image for larger version.
ID:	35713   Click image for larger version.
ID:	35714   Click image for larger version.
    10,779
    01:30 AM
    I havent noticed it here.... But thats pretty damn funny. Its like Cookie Monster, LOL.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    290
    01:30 AM
    The only 3 things I can think of that might change palette sizes are:
    1. Changing display resolution
    2. Remoting-in from a different computer (similar issue to item 1)
    3. Modifying/deleting Windows Registry entries
    July 7, 2017
    Hernando, MS
    560
    01:30 AM
    All it takes is closing a file and then opening another file, while Revit stays open to the Recent Files window. Happens every single time. Happens on every machine with 2019.2 installed in our office. Prior releases (original 2019 release) do not exhibit this behavior.
    6,329
    02:30 AM
    I have my palettes on my 2nd monitor and haven't noticed this at all, so it seems to be related to having them docked in some way.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,520
    12:30 AM
    I'm on 2019.2 and have the palettes docked and haven't noticed this issue. I do have them docked in a single column, rather than two, so maybe it's certain docking arrangements?
    July 7, 2017
    Hernando, MS
    560
    01:30 AM
    Well like I said, it never happened on any release, ever, before 2019.2 update. I've been using Revit this way ever since the Properties Palette was introduced a decade (?) ago - full height PP and full height PB both docked on the left side. Per Autodesk support I tried updating my GeForce driver, and tried changing various hardware and graphics settings. Nothing changed. Here is a video of what's happening: https://www.youtube.com/watch?v=svyQ4H1zv6g
    Notice how the right edge of the tool bar is under the Ceilings button. After closing the file and opening another, the PP briefly displays the full width of the previous PP and PB combination, then gets wider and splits into the 2 tool bars. Closing and then opening another file makes it happen again, getting wider still.
    July 7, 2017
    Hernando, MS
    560
    01:30 AM
    Strangely if I keep the file open and then open a second file, the toolbars stay put, I guess because they're already open as the second file opens. It's only when a file opens with nothing else open that this happens.
    6,329
    02:30 AM
    Have you tried deleting your UIState.dat file? https://knowledge.autodesk.com/suppo...interface.html
  1. Properties and Project Browser Frozen
    By Karalon10 in forum Architecture and General Revit Questions
    Last Post: January 22nd, 2019, 05:24 PM
  2. Properties Box and Project Browser Not Clickable
    Last Post: July 21st, 2017, 11:27 AM
  3. Properties and Project Browser not showing entirely
    By helpless af in forum Architecture and General Revit Questions
    Last Post: December 1st, 2016, 05:35 AM
  4. Properties and Project Browser Locked together
    By JD003 in forum Architecture and General Revit Questions
    Last Post: July 4th, 2016, 01:27 PM
  5. missing project browser & properties icon
    By frelli in forum Architecture and General Revit Questions
    Last Post: June 19th, 2014, 05:06 PM
