Thread: Arrays and constraints
    February 20, 2019
    Melb AU
    06:13 AM
    First time poster.
    Refugee from a different BIM platform struggling with Revit family creation.
    Making a simple duplicating linear family which calls the duplicating element (separate family)and sets its width W based on the overall length of the parent family , L and the desired number of instances, N.
    Controlling W for the duplicating element works but when using an array to duplicate the element using a reference plane controlled by W for the first duplicated element, it throws a "Constraints are not satisfied" error when changing N rather than adjusting the first duplicated element to the new position of the reference plane.
    Is there something about the groups created in Arrays that does not allow their position to be controlled/locked to a reference plane?
    help.
    (it would be so much easier to using code rather than Revit's formulas )
    3,226
    03:13 PM
    Quote Originally Posted by Badadoo View Post
    First time poster.
    Welcome to this forum.
    Sounds like you are constraining the nested family in two places? For example, left side and right side, or bottom and top? That will create an error. Constrain only left and bottom (for example), and then associate height to height, width to width, and it should work. Adding a picture to this kind of questions would be useful.
  1. Arrays in families
    By DavidLarson in forum Architecture - Family Creation
    Last Post: May 2nd, 2018, 04:04 PM
  2. 'Join' Multiple Arrays
    By beau21 in forum Architecture and General Revit Questions
    Last Post: November 28th, 2016, 08:04 PM
  3. Applying materials to arrays
    By cheinaranta in forum Architecture - Family Creation
    Last Post: April 19th, 2013, 12:06 PM
  4. Instance parameters in Arrays
    By KWilkinson in forum Architecture and General Revit Questions
    Last Post: February 18th, 2013, 09:26 PM
  5. How do you set up arrays less than 2
    By simon1688 in forum Architecture - Family Creation
    Last Post: December 16th, 2011, 05:04 PM
