Thread: Basic(?) Panel by Pattern
    September 11, 2013
    78
    12:43 PM
    Hi All,
    I'm attempting to make what I thought would be a fairly simple panel shape, but I can't work out how to keep a centre point/line in a rectangle.
    All I want is a rectangle panel with a line in the centre I can offset:
    Whenever I change the grid shape the centre line moves out of position, and any attempt I've made to keep it in the middle just throws up 'constraints not satisfied' errors and shifts the line:
    How do you constrain things with this type of family? It seems totally polar to the normal family creation process...
    I'm hoping this is an easy fix and I've missed something obvious, any help would be appreciated.
    Thanks
Name:	Panel Shape Right.PNG
ID:	36159   Click image for larger version.
Name:	Panel Shape Wrong.PNG
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    01:43 PM
    Place a point hosted on a line, and you can control where it's placed as a ratio. Choose 0.5 as the ratio, and it will be the middle point.
    Connect two points, and your have a middle line
    Sendt fra min ONEPLUS A5000 med Tapatalk
    September 11, 2013
    78
    12:43 PM
    Worked this out literally 2 minutes after posting here, after struggling with it for hours
    I placed 2 new points at the mid-points of the existing ref lines, then created 2 new offset points based on those:
Name:	Panel Shape Fixed.PNG
    September 11, 2013
    78
    12:43 PM
    Quote Originally Posted by tuekappel View Post
    Place a point hosted a line, and you can control where it's placed as a ratio. Choose 0.5 as the ratio, and it will be the middle point.
    Didn't see the ratio option, but I'll check it out - thanks!
    February 6, 2012
    338
    01:43 PM
    Quote Originally Posted by Grumple View Post
    Make the ration option a parameter, and you can have panels that change their angle based on that. Allows you to nudge your design in the direction you want, if you're into that kind of stuff.
ID:	36163   Click image for larger version.
  1. Pattern Based Curtain Panel - Keep Panel Extrusion aligned
    By christianism in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 12th, 2018, 02:49 AM
    Last Post: October 25th, 2017, 01:15 PM
  3. Offset of curtain wall panel form basic wall
    Last Post: January 20th, 2016, 11:17 AM
  4. Need help with the pattern panel
    By inec in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 27th, 2015, 04:23 PM
  5. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
