Thread: Get all the junctions of walls/floors elements
    April 2, 2019
    09:49 PM
    Hello,
    I would like to get all the intersections of elements (walls, floors) which make a room boundaries.
    For each of those, I need to get its length and the two ajacent elements (walls and/or floors) which make this junction.
    I tried using Room.Boundaries but when I get all the boundaries elements, how can I find each junction made by all these elements ?
    For exemple, for a given wall, you could have 3 or 4 different floors elements that make a junction with this wall.
    Many thanks in advance for your help!
    April 12, 2019
    12
    09:49 PM
    hey,
    can you show us what did you do so far? also, do you want to autojoin them using dynamo or any other goal?
    Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    72
    04:49 PM
    gui_foucart:
    Also after you post a screenshot, maybe identifying what you are attempting to achieve in the long run? What is the absolute final end goal? Are you just wanting a X,Y,Z point of the intersection of these objects to export to a .csv? Toggle a Yes/No parameter in the element that is has an intersection? etc.
    The answers can take us down different paths to solving the issue you proposed.
  1. Make elements visible thru other elements (like walls) in an elevation
    By engineer in forum Architecture and General Revit Questions
    Last Post: February 16th, 2018, 01:27 PM
  2. Continuity between walls and floors
    By piper76 in forum Architecture and General Revit Questions
    Last Post: August 29th, 2016, 11:08 PM
  3. SFL, FFL, floors, walls and doors
    Last Post: September 28th, 2014, 10:20 PM
  4. Floors - Modify Sub Elements - Revit wants to remove references
    Last Post: October 15th, 2013, 03:58 PM
  5. align command with floors (sub elements)
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: June 15th, 2011, 02:23 PM
