Thread: Search Set Not Finding Family Components
    Member koolair's Avatar
    July 31, 2014
    276
    11:48 PM
    I have a bunch of air handlers from a supplier, and it includes a coil pull clearance box and door pull clearance box. When I select an AHU, expand it i the selection tree to the limit, I see the clearance object as geometry. I can manually select it in the view.
    However, I can't seem to capture these geometries via search sets.
    For context, I have 10 air handlers each with its own clearance box. I want to toggle all of them on and off via search set, hide/unhide.
    Any ideas?
    Sent from my SM-N950W using Tapatalk
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    399
    05:48 AM
    Sound like they modelled the Clearances as geometry straight into the family, instead of making them into their own object with their own properties and then nesting them. The result is now that you don't have properties to enable a Search Set.
    This would either take a very detailed look at the selected zone and figure out a property that is unique to only the clearances, or a conversation with the people who made the content. (Better yet, build your own version)
  1. Using "File Name" Field as Search Criteria / Search Sets
    By mcabaltera in forum Coordination Tools
    Last Post: December 12th, 2014, 03:03 PM
  2. Plan visibility of nested family with shared components.
    By jmk in forum Architecture - Family Creation
    Last Post: October 1st, 2014, 05:20 PM
  3. Finding file path of Family
    By clickster in forum Architecture and General Revit Questions
    Last Post: July 13th, 2014, 02:23 PM
  4. Merge similar materials across family and host components?
    By quantumk in forum Architecture - Family Creation
    Last Post: January 24th, 2013, 12:00 AM
  5. How to search/find a family type (with a particular parameter) in your library?
    Last Post: July 12th, 2011, 06:48 PM
