Thread: Stand Pipe symbol on every floor?
    Junior Member deepblue02101996's Avatar
    November 22, 2017
    San Francisco
    28
    02:50 PM
    Community;
    i had a question regarding creation of a stand pipe family; i currently have an elevator family that when placed on the ground floor has the generic cabin repeat on every floor above it that i specify in a given height. i was hoping to make the same with a Stand pipe family. please find enclosed the two families that i am using and let me know if anyone has any advice in family creation to pull this off?
    let me know if anyone has any suggestions on improvement!
    thanks!
    3,127
    01:50 PM
    Add a invisible line that extends from the base to the "top". As long as this line intersects the cut plane of a level the family will show up in the view. If your family provides a parameter to set the overall height make sure your line is governed by this parameter so it crosses through ever floor's cut plane.
    November 22, 2017
    San Francisco
    28
    02:50 PM
    thats it!!! awesome! thanks!
  1. Replies: 6
    Last Post: January 30th, 2019, 08:04 PM
  2. Pipe Cap Symbol
    By RobDraw in forum MEP - Family Creation
    Last Post: August 14th, 2017, 08:31 PM
  3. Flow Direction symbol in chilled water pipe line
    By santhorathi in forum MEP - General
    Last Post: February 16th, 2016, 09:32 PM
  4. Pipe tag indicates under or above floor
    By Menline in forum MEP - General
    Last Post: October 20th, 2014, 03:45 PM
  5. Pipe Fitting Symbol Problem
    By bhanna in forum MEP - General
    Last Post: September 20th, 2011, 09:51 PM
