Thread: 2017- adding mutliple revisions to sheet index
    June 26, 2014
    98
    04:23 PM
    i have figured out how to add a column to the sheet index that reflects the revision if the sheet has a revision. now i would like for the index to reflect multiple revisions if said sheet has multiple revisions present. an example would be that we have revisions for our county submittal and revisions for owner changes at the same time. county is designated with a number and the owner is designated with a letter. so sheet A1.1 might have county and owner revisions on it and in the sheet index i would like to see both listed.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    395
    11:23 AM
    I believe that its not possible using the out of the box "Current Revision" parameter.
    I think you can do that using your own shared parameters but that won't be linked back into Revit's revision schedule
    "Current Revision" only does what is says - shows the current Revision. Can't show 2 revisions as one of them isn't current.
    Do you have an issue with just adding them in as separate revisions?
    Rev 3 for County, then Rev E for Client........ & so forth?
    You have to print out the different sets anyway (One for County & One for Client)
    Good question!
    2,779
    09:23 AM
    Dwane is correct, OOTB Revit doesn't provide the ability to schedule multiple parameters per sheet. It would be pretty easy to do using Dynamo though. You could definitely modify the script shown here to write multiple revisions to a custom parameter/s.
    July 21, 2018
    90
    09:23 AM
    You could duplicate the views and have a second set of sheets - one for client, one for submission?
    We're about 2 months into trying to re-standardise our revisioning in the office, I don't think we've made any progress
  1. Replies: 4
    Last Post: May 3rd, 2018, 11:02 PM
  2. Drawing Index & Issued Revisions
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: September 8th, 2017, 07:09 PM
  3. sheet index (list) not organizing properly 2017
    Last Post: September 15th, 2016, 08:04 PM
  4. Shading in a sheet index
    By npalmitessa in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 10:56 PM
