Thread: Window Family Adjust and cut multiple walls
    February 16, 2017
    London
    11
    04:29 AM
    Hello all,
    I've been stuck for some time now and having to make temporary fixes which is longer really an option.
    So the window two glazing units, an interior and exterior, as well as a plate which sits flush with the internal wall face.
    I'd like to make the family adaptable, in that it's able to adjust to the varying thicknesses of walls, and move in internal glazing unit flush with the internal face, and likewise the external with external face.
    I have wall build ups which are made using several separate walls. So the family is currently attaching to one of the walls and not acknowledging any of the others even if they are joined.
    I've attached an image and the RFA file.
    I would appreciate any suggestions, or if its even possible?
    Thanks
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    07:29 PM
    Without opening it....you have to control your opening with a void(s) and take account of the void extending past the host wall to allow to exceed the widths of any adjoining wall.
    February 16, 2017
    London
    11
    04:29 AM
    I don't understand how this will allow the rest of the window components to adjust to the varying wall thicknesses. What you've described is something like i've been doing up until now which required manual adjustment for each varying wall buildup.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    380
    05:29 AM
    Host the components in the family on various Reference Planes (Parallel to the host wall in the family.) Make those parametric with different parameters so you can position them differently.
    The window will not automatically pick up the widths of the "extra" walls in your project, you need to enter those values yourself.
    Make sure the void(s) in your family are deep enough to cut the entire wall composition and Join the different Wall Layers so the Void will cut through them all.
    Las Vegas, NV
    4,864
    07:29 PM
    BTW, if you use the wall opening in your window family and in the project just join the adjacent walls to the wall your family is hosted to and they will assume the opening too.
    And yes, if you use voids you have to adjust the voids as needed for different wall types...or change the widths to accept all walls.
    February 16, 2017
    London
    11
    04:29 AM
    Thanks for the advice. I'll give your suggestions a go
  1. Hanging Light Family on Sloped Roof - Make Cables Parametric to adjust for slope
    Last Post: July 16th, 2018, 09:40 PM
  2. Wall Based Family - Can't Adjust WorkPlane, Moves When Parameters Altered
    By Limbatus in forum Architecture - Family Creation
    Last Post: November 12th, 2015, 01:58 AM
  3. Window Jamb Doesn't Adjust to Joined Wall
    By Kristjan in forum Architecture - Family Creation
    Last Post: February 15th, 2015, 07:49 AM
  4. Adjust view range in family document
    By qutaibah in forum Architecture and General Revit Questions
    Last Post: October 3rd, 2012, 08:29 PM
  5. Stacked walls vs multiple walls
    Last Post: January 27th, 2012, 04:05 PM
