Results 1 to 10 of 15
Thread: Facebased Family
    November 27, 2012
    634
    04:48 PM
    Facebased Family
    I have seen Paul Aubins, work around for getting a wall based family to facebased or un-hosted.
    but is there anyway of getting a face based family to become un-hosted?
    Cheers
    1,628
    05:48 PM
    There is a trick.
    In the family select the Host extrusion.
    In the properties you'll see the Extrusion Start and End. Set both of those to 0
    Revit will complain about Constraints not satisfied, choose Remove Constraints.
    Then Revit will complain about Extrusion is to thin, choose Delete Element(s)
    In the properties now uncheck the newly visible Work Plane-Based
    You now have an unhosted family
    BUT, you can not set the offset of the family in your project. So it is unhosted, but has limitations.
    Not having the offset can be interesting for some families, where you want the hight above level to be part of the parameters in the family.
    When I found this out I wanted to change my fire emergency families to one of those, but it would be again a lot of time
    November 27, 2012
    634
    04:48 PM
    There is a trick.
    Thanks for that. Everyday is a school day
    1,628
    05:48 PM
    I edited my post right after you reacted, so not sure you have seen that. So my BUT:
    November 27, 2012
    634
    04:48 PM
    Just tried it out. With a electrical fixture it just gets hosted to a level. I unticked work plane based.
    Reason I want to do it is we doing a big apartment block with 100s of rooms but only a couple of different types. I wanted to create model groups of these types. So not having to change everything in each room if there is a change and i believe hosted elements dont work well in model groups
    1,628
    05:48 PM
    As long as you host the families to a wall that is also in the model group it should be OK, but I still don't use hosted families because you would need 2 of them, one hosted and one un-hosted and that not right
    But electrical fixtures are either wall based of un-hosted and the trick I posted above does not work with wall based families because there is no way to remove the wall from a wall based family as far as I know.
    November 27, 2012
    634
    04:48 PM
    We use face based for most of our electrical fixtures. And the wall would be there but in the linked arch model so think it causes problems as the wall is not in the group.
    1,628
    05:48 PM
    Quote Originally Posted by nick_h View Post
    Yes it would.
    So if for some reason you are not able to remove the extrusion from the family to turn it into an unhosted family you would have to recreate them I think. Are yiy able to post ibw of your electrical fixtures so we can have a look for maybe a solution?
    November 27, 2012
    634
    04:48 PM
    Yes it would.
    here you go.
    2,821
    08:48 AM
    https://knowledge.autodesk.com/suppo...ily-revit.html
  1. 2d Family vs 3d Family; Multi-Family Residential
    By deepblue02101996 in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:47 PM
    Last Post: March 27th, 2016, 07:18 AM
  3. NewFamilyInstance facebased copy to Element wrong Reference
    By DevDemon in forum Third party Add-Ins, API and R&D
    Last Post: June 12th, 2015, 06:08 AM
  4. Facebased family symbol won't show.
    By GabrielBlack in forum MEP - Family Creation
    Last Post: January 14th, 2013, 09:24 PM
  5. facebased structural connection and hidden lines issue
    By jh75 in forum Structure - Family Creation
    Last Post: August 16th, 2012, 03:16 PM
