Results 1 to 10 of 18
Thread: Angular Facade Geometry
    September 11, 2013
    75
    12:44 PM
    Hi All,
    Just a quick question regarding how you would create a facade that looks similar to the below image:
Name:	Facade Geometry.PNG
    Can this be done with components? Or is it only sweeps/extrusions or 'wall by face'?
    I've experimented with walls and architectural columns, trying to get them to attach to angular slab edges or beams - but they don't work.
    The only way I can think of doing this is with in-place family tools, but I'd rather avoid any of that if possible.
    Any ideas?
    Cheers
    1,402
    01:44 PM
    It kinda depends on what it is and how much of them are there.
    I used Generic Models in the past to do this.
    All prefab concrete:
    4,415
    12:44 PM
    Quote Originally Posted by Grumple View Post
    GM nested within CWP.
    September 11, 2013
    75
    12:44 PM
    I don't think that will work, because these are large components that are 'framing' curtain wall elements and balconies etc...
    September 11, 2013
    75
    12:44 PM
    I'd rather try to avoid making 'custom' elements to produce the various corners etc... but it seems like that might be the only option.
    Autodesk JeffH's Avatar
    792
    07:44 AM
    Maybe an adaptive panel component might work? You could have one typical component for most of the "field" so to speak and then an adaptive component panel for the more unique situations?
    4,415
    12:44 PM
    Trust me, it does, on the proviso it's adopted as part of a planned implementation - where said glazing and balcony elements are built within arrangements (which obviously might not help you in this instance).
    I haven't any facades with chamfered pieces (like Robin's* & yours) to hand - but here's an example of wavy-shapes (!?) following the same method:
    where everything you see in this shot is a GM (tab-selected) nested within a CWP arranged within a pattern of the CW (hover-selected).
    This is where panelisation quickly becomes a question of design management - not modelling software functions. At some point someone somewhere is going to need to consider, cost, detail etc all those variants - and whilst you might not need to go as far as making an AC as Jeff suggests - families feat. parametric controls* really come into their own here.
    *starting with simple stuff like yes/no (user-orientated) controls for controlling geometric stuff like "show left return", "has solid infill", "parapet condition", "sill element" etc
    *Robin, Q. are your pieces individually placed/stacked/aligned elements?
    September 11, 2013
    75
    12:44 PM
    where everything you see in this shot is a GM (tab-selected) nested within a CWP arranged within a pattern of the CWM (hover-selected).
    So even the curtain walls (panels and mullions) are all GM families?
    Doesn't this break the intelligence within Revit of being able to schedule the curtain wall types and curtain panels etc...?
    4,415
    12:44 PM
    Got it.
    For all of about a nano-second until you realise that that "intelligence" is only what one makes of it.
    GMs are just as schedulable. And Revit categories mean nothing outside of Revit.
    Understand, the GM-hate drum has been banged for far too long.
    2,667
    05:44 AM
    As has category purity.
  1. How do I make this angular junction
    By viratmanchanda in forum MEP - General
    Last Post: December 24th, 2015, 07:48 PM
  2. Angular Parametrics
    Last Post: August 10th, 2015, 06:42 AM
  3. Angular Facade, how would you go about it?
    By nPoika in forum Architecture and General Revit Questions
    Last Post: March 27th, 2014, 01:41 AM
  4. Dimension - Angular
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: October 29th, 2013, 05:02 PM
  5. Inputting Angular Dimensions
    Last Post: November 26th, 2012, 06:02 PM
