Thread: Volume por Familia
    May 16, 2019
    08:13 PM
    Volume por Familia
    Good afternoon!
    I need to get the volume of complex families per shared parameter, could anyone help me?
    How do I get the native volume, the one that appears in the tables, but I need to put it in the shared parameter, could you help me?
    November 19, 2018
    12
    12:13 AM
    Hi! How about using BIMLink add-in in order to export your schedules with the desired built-in parameters and the new shared parameters. Then you change the Excel by copying the values that you want to the shared parameter column and import it back to revit.
    It is not a "live" solution, so you will have to do this every time that you want to transfer those values.
  1. Repetir objetos de una familia
    By yanelisgs in forum Foro Español
    Last Post: August 27th, 2017, 11:49 PM
  2. insertar familia
    By memoarq in forum Architecture and General Revit Questions
    Last Post: July 17th, 2017, 12:32 AM
  3. Familia de enchufes y tomacorrientes
    By gru3d in forum Foro Español
    Last Post: June 15th, 2016, 08:40 AM
  4. Familia paramétrica. Félix Candela.
    By russoo in forum Rendering and Gallery
    Last Post: December 17th, 2012, 12:06 PM
  5. Mass Volume Vs Building Volume
    Last Post: March 23rd, 2012, 12:14 PM
