Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Vertical Clashes in Navisworks
  1. #11
    11,160
    07:49 AM
    Graph image, and screen shot attached.
    Then use that property (or any property you wanted) in Navis for your search set.
ID:	36885   Click image for larger version.
  2. #12
    January 17, 2011
    2,115
    07:49 AM
    Verticals have an actual slope of "Not Computed" aka <blank> or "". So you can search for- and find- that, and write data to the pipes with the Slope set to "".
    I would also advise that when the slope tool is turned on, and you change an elevation that puts in a vertical, there's a very slight slope still applied to the intended vertical pipe. It's kind of a glitch in Revit, if you ask me, but not technically because you can and sometimes need pipes to "lean" in the vertical ever so slightly.
    I say this because it's a real thing in models, so I wanted you to be aware in case there was a less than or greater than that could be applied. Only OCD people like me will turn off the slope tool before I create a vertical through the elevation change, then turn it back on to continue with my sloped pipes. But this also can happen through slight edits, etc.
    Anyways, it may be splitting hairs, but if I had the option to include something that captured "leaning" vertical pipes, I would include it.
    -TZ
  3. #13
    11,160
    07:49 AM
    No, its not splitting hairs: Its the exact reason i wouldnt keep the graph this way, if we wanted to assign a *tolerance* that we were considering *vertical.*
    In that case, i would collect startX, EndX, startY, endY, and StartZ, EndZ of the pipe, and set up some rules. Graph would be much bigger... But since i dont know what the assumptions or rules are yet, i couldnt do it if i wanted to. But its totally possible.
  4. #14
    11,160
    07:49 AM
    So, Tannar's post made me curious, because those are the nuts-and-bolts problems we have to be able to solve, or our "solutions" arent real, and thats worthless. So i modified the graph to use the other approach, i discussed. This means there is now essentially a TOLERANCE you can enter: How far apart the start and end points of the pipe are (in feet and inches) that you still want to consider it "vertical." For right now, i set mine to 1/4". That means no matter how high up and down the pipe goes, if the X,Y point moves more than a 1/4", its not considered "vertical." This allows it to catch the modeling idiosyncrasies Tannar was talking about. And- of course- if you also want to catch pipes that are largely vertical but also canted at an angle, you can set that tolerance to be any value you want: 1'-0", or something.
    Then, i got curious how many pipes are like this, so i opened an MEP model i happen to have here, and ran both graphs:
    The one that uses the SLOPE parameter found: 1556 Pipes
    The one that uses the TOLERANCE method found: 1696 Pipes.
    An extra 140 pipes, that are modeled as Tannar described.
    Thanks for the tip, Tannar. Now we have something lightweight and usable. The graph could certainly be optimized a bit. In the chunky middle section i doubled up some nodes, because im not great with lists and whatnot. A real Dynamo guru could clean it up and make it more better.
    The graph itself:
    1. It collects all the Pipes
    2. Gets the start and end points of their Curves.
    3. Gets the X and Y values of those points.
    4. Performs a subtraction of Start X - End X, and Start Y - End Y, in two parallel branches.
    5. takes the result of number 4, and gets the absolut value of it (no negative values since we dont care about direction)
    6. Checks to see if it is greater than or equal to our "Tolerance" node, which is currently set to 1/4".
    7. Creates a list of both comparisons lists (giving is twice as many true or false "answers."
    8. Transposes the list, which means breaks them in to smaller lists (one per pipe) of both true or false answers from number 6.
    9. Looks for ANY of the conditions (of the two) to be TRUE. Filters those out, since those are the NON vertical Pipes.
    10. Takes the REST and sets the Comments to say VERTICAL, for Navisworks to Search Set. Of course, you could use any parameter you wanted, here. If i were doing this often, id make a Shared Parameter for it, personally.
Name:	Parallax Team-90-Project Data-Plumbing-Find all Vertical Pipes.png
ID:	36887   Click image for larger version.
ID:	36888   Click image for larger version.
  5. #15
    2,830
    05:49 AM
    Good job Aaron!
  6. #16
    11,160
    07:49 AM
    Thanks! Im thinking this needs to be a simple push button app, at some point. Not just this workflow, mind you, but there are a bunch of small *data pushes* that we do, prior to exporting to Navisworks. Maybe we need some ******* push buttons for that.
  7. #17
    May 24, 2017
    6
    12:49 PM
    Could you not just add a comment in a non used Revit parameter field that says "I am vertical" (or some such lol) and make a search set in NW?
    Sent from my Pixel 2 XL using Tapatalk
  8. #18
    11,160
    07:49 AM
    Quote Originally Posted by kboydsheppard View Post
    Sure... If you want to manually hunt around and manually select ever pipe or duct that is vertical or close to vertical, to enter that parameter in.
    Or you run the graph and it automatically does exactly what you are talking about.
    I guess if you get paid by the hour your way makes sense... Otherwise: automate.
  9. #19
    May 24, 2017
    6
    12:49 PM
    Bah.... Isolate a 3d view to just pipes, view cube orient to an elevation, crossing window select horizontally..done
    Or add the comment as you add each pipe.
    Or do I miss something
  10. #20
    May 24, 2017
    6
    12:49 PM
    I mean if you're looking for vertical clashes those pipes are going to go from level to level anyway so they should be easy to select any that dont go level to level or is too short isn't worthy of a clash anyways?
    Last Post: October 29th, 2018, 11:15 PM
  2. Import Clashes from Navisworks to Revit
    By alexo4141 in forum Third party Add-Ins, API and R&D
    Last Post: February 10th, 2016, 03:46 PM
    Last Post: May 3rd, 2015, 11:16 PM
  4. Navisworks - Stop focussing on clashes
    By domsib in forum Coordination Tools
    Last Post: October 15th, 2014, 03:37 PM
  5. Removing clashes
    By mona miller in forum Coordination Tools
    Last Post: September 30th, 2014, 02:26 PM
