Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Vertical Clashes in Navisworks
  1. #21
    11,091
    06:09 PM
    Quote Originally Posted by kboydsheppard View Post
    Bah.... Isolate a 3d view to just pipes, view cube orient to an elevation, crossing window select horizontally..done
    Or add the comment as you add each pipe.
    Or do I miss something
    Sent from my Pixel 2 XL using Tapatalk
    If you want to do it that way, go for it.
    You miss a lot, if you want my honest opinion. You ASSUME about level to level, you ASSUME about being able to properly select them all with a crossing window selection, you ASSUME only certain lengths or heights will be important.... And for what:
    To support a more labor intensive and manual method that's still slower and more error prone than what's shown above, simply so you can... Not use Dynamo?
    What's the aversion to using smarter workflows? It's odd to me that you want to argue that doing it 100% manually is better. Running that graph takes less than 10 seconds per entire model. You cant do what you are describing anywhere near that fast.
  2. #22
    May 24, 2017
    6
    11:09 PM
    Wow sorry just thought to have a DISCUSSION didn't mean to come across like I was ATTACKING you
  3. #23
    11,091
    06:09 PM
    I thought we were having a discussion, too.
    In that discussion, im trying to figure out why manually making isolated 3d views, and doing orient to a view or plane, using several selection windows (at least one for every level), and manually typing a parameter value, is so much (or any) better than using an automated system, that you would want to disencourage folks from using automation...
    Any reason in particular?
    Last Post: October 29th, 2018, 11:15 PM
  2. Import Clashes from Navisworks to Revit
    By alexo4141 in forum Third party Add-Ins, API and R&D
    Last Post: February 10th, 2016, 03:46 PM
    Last Post: May 3rd, 2015, 11:16 PM
  4. Navisworks - Stop focussing on clashes
    By domsib in forum Coordination Tools
    Last Post: October 15th, 2014, 03:37 PM
  5. Removing clashes
    By mona miller in forum Coordination Tools
    Last Post: September 30th, 2014, 02:26 PM
