Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Cleanup AutoCAD dwg for previous faraway Origin
  1. #11
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    05:19 AM
    Well...the drawing is in mm. Your border you added is 832 miles away from the origin.
    Draw a line from your border to 0,0,0....you want to be as close as possible to that. I moved your box to the origin and saved, linked it into my project with no error messages.
    Yeah, i know....-the thing is, our Landscape architects like to draw on top of surveyors' files, hence the faraway origin. And i'd like to keep the workflow as clean as possible, so moving their geometry is out of the question.
    But, you're right, i know too well about the limitations of Revit and surveyors' files.
    I think my conclusion will have to be that i Xref/attach the LARCH file(units in mm) into a file that has meters as units. And that will be the file i link into Revit. Revit has a problem with large numbers, so it usually helps to convert to meters.
  2. #12
    2,712
    09:19 PM
    Quote Originally Posted by tuekappel View Post
    When you xref the file try moving the xref so its centered over the host files world origin, then save the file for future updates. To get it ready for Revit bind the xref and explode it. Then explode it again, and again until theres nothing left to explode (this to remove origins from blocks that are not logical to the geometry) - truthfully you may not need to explode over and over but its the safest approach. Then flatten everything (except topography if youre using it), purge all, and save as a new file. This file can now be used in Revit without the issue of extreme geometry extents and is a fairly quick and repeatable process.
  3. #13
    May 18, 2011
    Calgary, AB
    426
    09:19 PM
    Would this help?
    https://www.revitforum.org/architect...tml#post189250
    "A new trick I learned: use COPYCLIP on the part of the CAD file you need (assuming you have and can open it in AutoCAD). That will create a new file with only the geometry you need, AND it will maintain the coordinate system, which is important if you have to export and send things back to your civil/site engineer.
    I used to always move stuff in the CAD file to 0,0,0, but found it's better to use COPYCLIP so that the coordinate system is maintained, so that when I Acquire Coordinates my Revit model will have the same coordinate system. You can have the Site Survey Point more than 20 miles away from your Revit model, it just doesn't like model geometry that far away. "
  4. #14
    3,116
    08:19 PM
    Id avoid CopyClip, that uses Windows clipboard and is likely to be less accurate than WBlock, which can write a new file based on what is selected. It (WBlock) respects the original WCS coordinates of the file without risking Windows translation during the clipboard operation. The placement options for copyclip are enticing but the precision during the translation might introduce tiny errors we are hoping to avoid to begin with.
  5. #15
    2,689
    02:19 PM
    I’d avoid CopyClip, that uses Windows clipboard and is likely to be less accurate than WBlock, which can write a new file based on what is selected. It (WBlock) respects the original WCS coordinates of the file without risking Windows translation during the clipboard operation. The placement options for copyclip are enticing but the precision during the translation might introduce tiny errors we are hoping to avoid to begin with.
    I wasn't aware of that, guess I'll be using WBLOCK from now on. Cheers Steve
  6. #16
    3,116
    08:19 PM
    Copy and Paste are Windows in Revit too
    It might be accurate enough but makes me even less comfortable having to link the files at all does.
  7. #17
    2,689
    02:19 PM
    I find slightly out of alignment things in Revit get aligned with copy paste
    I wouldn't do it with say, a property line though.
  1. Link Origin to Origin or Shared Coordinates?
    Last Post: April 25th, 2017, 01:18 PM
  2. Replies: 4
    Last Post: October 25th, 2016, 07:20 PM
  3. AutoCAD link origin change issue
    By archi in forum Architecture and General Revit Questions
    Last Post: April 12th, 2016, 10:48 AM
  4. Renovations to a previous job
    Last Post: December 18th, 2013, 02:29 PM
    Last Post: March 4th, 2013, 11:15 PM
