Results 1 to 10 of 17
Thread: Cleanup AutoCAD dwg for previous faraway Origin
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    11:31 PM
    Hi All
    I'd like to link a DWG from our LARCH, but i keep geetin the dreaded "some numerical data blablabla...."
    I've tried it all:
    • deleted all faraway geometry
    • established UCS World in the center of the geometry
    • used Wblock to export geometry only
    • Purge All
    • deleted all XRef's
    -and still the dwg insists it has something placed in it's old origin. At least that's how Revit sees it.
    I suspect it's a remnant from the now deleted Xrefs og some block, but how do i clean that up?
    And more important: how do i avoid going through the above steps every time i need to link a LARCH file into my Revit file?
    I solved the problem for now by changing the units to meters, but i'd like to avoid that, too.
    Any good workflows out there?
    June 21, 2012
    Tours, France
    1,116
    01:31 AM
    Did you already "Unhide", "Unfreeze" all objects/Layers and have you use the -Pu (Purge but more deep)?, I don't want to point to the obvious but some times for me this worked!
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    03:31 PM
    Change the view to 3D.... A lot of people keep thinking 2D and looking for items miles away in the X/Y plane and forget about the Z.
    3,171
    04:31 PM
    I've encountered blocks (playground equipment in my case) that have large extents. If you explode all the blocks in the file you may find such an issue. I'll often break a file into quadrants, delete everything in one and then the next until the error message goes away. Then I work in the quadrant and repeat until I figure out what element(s) is generating the warning.
    Member scourdx's Avatar
    July 4, 2013
    57
    03:31 PM
    Post the file and let us take a look. One work around I find useful is I link in the CAD drawing and use Revit Crop view. Crop around the CAD link and then export the to DWG. This will clean up all the mess outside the drawing and you only show what was cropped.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    248
    11:31 PM
    Most times there is a lot more information on the DWG than you need in Revit.
    Just copy the things you need into a new DWG and link that 1 into Revit.
    Or even better, don't link it in Revit, just draw native Revit with Autocad on another screen so you will not go 0.0000263478 mm off on every wall.
    I just did a start of a project (150 apartments ) where there were DWG exports from another program and we used it to draw the grids and the walls.
    Two days later i noticed there was something off and first we thought it was just the walls but it was also the grid, so that costs us 30 hours.
    It was also the last time i will even link a DWG into Revit.
    You can also see it's not even parallel to eachother.
Name:	DWG is ****.PNG
    February 6, 2012
    338
    11:31 PM
    Thank you for all your helpful comments. I'm not being sarcastic. i love this forum.
    Just to adress the most important:
    I've tried almost everything, also copying geometry into another file. It sometimes helps, sometimes not. I've tried to explode every block down to bare lines, it sometimes works. Sometimes not.
    Yes, i save layer state, and then unhide, unlock, etc, all layers, before i do anything.
    Yes, i know Acad is 3D, too. I modeled 3D in AutoCAD before most of you were soiling your diapers, thankyouverymuch *smiling*
    My main goal is to establish a worksflow, so that i just have to reload the LARCH file everytime there is a change.
    Attached is the LARCH file with all geometry deleted, i've drawn a 100x100m rectangle. i KNOW there's a WCS far away from the geometry, but i've experienced files where this isn't a problem in Revit. These files are always exported from surveyors custom software, i don't understand why Revit can't accept a ACAD tile with an origin that far away, when there's no geomtry....
    February 6, 2012
    338
    11:31 PM
    BTW, this is what a "truncated" file looks like in Revit. Looks like a timeline of my education :-)
    Does anyone know how to invoke the "rescale" dialog from the units dialog? It's like, some ACAD installs does it, some don't?
    I want to change units to meters, but also scale all text and annotations in the same procedure..
    whhoops, don't bother, i found it: Use [-DWGUNITS]
    Las Vegas, NV
    4,864
    03:31 PM
    Well...the drawing is in mm. Your border you added is 832 miles away from the origin.
    Draw a line from your border to 0,0,0....you want to be as close as possible to that. I moved your box to the origin and saved, linked it into my project with no error messages.
    July 10, 2015
    Boise, Idaho
    782
    05:31 PM
    Nothing like the time honored tradition of civil showing a line 1/16" long on the horizontal and 10 miles in the vertical
  1. Link Origin to Origin or Shared Coordinates?
    Last Post: April 25th, 2017, 12:18 PM
  2. Replies: 4
    Last Post: October 25th, 2016, 06:20 PM
  3. AutoCAD link origin change issue
    By archi in forum Architecture and General Revit Questions
    Last Post: April 12th, 2016, 09:48 AM
  4. Renovations to a previous job
    Last Post: December 18th, 2013, 01:29 PM
    Last Post: March 4th, 2013, 10:15 PM
