Results 1 to 10 of 15
Thread: Compoud Wall stutcure
    October 16, 2016
    442
    12:02 AM
    Hello all,
    When you create a wall with multiple layers (for example: concrete, insulation, Gypsum) in the core boundary do you put the structural material? In this case I need to put the concrete?
    Thank you in advance!
    6,387
    08:02 PM
    The Core layer of the wall is typically the structural element(s), but there can be exceptions. If you split your walls into core & finish, the material that ends up in the core layer isn't necessarily structural, but you have to have something there, otherwise it can't make the wall.
    October 16, 2016
    442
    12:02 AM
    What do you mean with 'split the walls'?
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    253
    12:02 AM
    Draw every layer as a single wall, it is more work, but it will give you a better material takeoff.
    October 16, 2016
    442
    12:02 AM
    Quote Originally Posted by mjajansen View Post
    I would like to know which material we need to put in the core boundary.. only the structural material like concrete?
    Each time that I create the walls separated I have problem with the windows as the wrap isn't correct.
    Also if I split the walls vertical as needed, I think that the material calculations are more or less correct..
    December 25, 2011
    The Netherlands
    253
    12:02 AM
    The layers in a wall have to do with connection with other walls, how the layers connect.
    https://knowledge.autodesk.com/suppo...4BB25-htm.html
    And for material takeoff, it calculates in the middle of the wall, so you will have too much innerwaal and not enough outer wall if you order by Revit schedules.
    If you want your windows to be good in seperated walls all you need to do is join the wall to eachother and the window will cut the other wall too.
    June 21, 2012
    Tours, France
    1,122
    02:02 AM
    ^^ + 1 for this! that's the way I'll model those walls!
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    12:02 AM
    Quote Originally Posted by Andres Franco View Post
    For the young Maria: Andres is joking. He forgot to put the /s in the end of his sentence :-)
    June 21, 2012
    Tours, France
    1,122
    02:02 AM
    Quote Originally Posted by tuekappel View Post
    my bad, after several years practicing my English is far to be good!
    June 21, 2012
    Tours, France
    1,122
    02:02 AM
    Just to clarify!; I do model all layers of my walls and floors as separate walls or floors, far better to quantify and to control visibility graphics, not ot mention that is more the way the things will be done!
Name:	wall layers.JPG
  1. Wall Top Condition in Wall Tag Without a Million Wall Types
    By twocon in forum Architecture and General Revit Questions
    Last Post: August 28th, 2018, 03:18 PM
  2. Wall sweep on an angled wall (modified wall profile)
    Last Post: June 5th, 2018, 08:54 PM
  3. Wrap wall sweep at wall opening on a continuous wall
    Last Post: April 27th, 2018, 09:13 PM
  4. create a wall sweep on an angled wall (gable end wall) (2017)
    Last Post: August 3rd, 2016, 06:34 PM
  5. Legend: Exist Wall, Demo Wall, New Wall.
    Last Post: May 29th, 2013, 06:00 PM
