Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: multiple versions of navisworks
  1. #11
    11,160
    07:51 AM
    Perfect. If licensing isnt an issue, i would do what Tannar suggested, and vaporize all but 2020. Thats all ive got on my system, now.
    (And get Properties+ (its free)) if you are primarily Revit users just getting in to Navis. Its worth it.
  2. #12
    3,358
    07:51 AM
    AThe new Collections licenses are way better about it, at least, when using the Named Account licensing: if a user is signed in on the machine, it doesnt matter what they open (from the same collection). So revit 2020, Revit 2019, AutoCAD 2018, etc. It doesnt penalize..
    Ditto for the Networked (FlexLM) Licensing.
    That used to take two licenses for different versions, and it no longer does.
    SO glad we no longer have to worry about running out of licenses just because we're in the middle of upgrading.
  3. #13
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    04:51 AM
    Hey- I just want to make sure: can we get a moderator or an admin to clarify: Does this mean once a thread is answered, its okay to let the posts that come after the answer be a free for all about whatever we want? Asking for a friend.
    To a point....we've always wound up continuing a thread when the post should be concluded, and I tend to not lock threads unless it gets out of hand.
    @hans...if you want to debate the Navisworks issue, please feel free to do so in the Out There section of the Forum. Just keep it civil please.
    OP is still commenting, so I won't be locking it unless posts continue to be unsupportive or not related to the question.
    Side note... You don't have to install every version of Autocad either. That can help with the hard drive space a little bit too.
  4. #14
    March 28, 2012
    Milton Keynes
    12
    01:51 PM
    If you want to save space on your SSD Drive:
    Keep only single installation of one of Navisworks 2016-2020 which is the latest and most compatible with your current Revit version you are using on your projects.
    Justification
    - You do not need older versions of Navisworks, because Autodesk is not updating this software anymore, except adding compatibility to BIM 360 Coordinate (formerly BIM 360 Glue) and giving some cosmetic changes. All Autodesk effort is moved now to BIM 360 Cloud platform.
    - You will find that Navisworks 2016-2020 share the same NWF, NWC, NWD file version, due to lack of changes, and when you save NWD you see option to save to 2016-2020 compatible file in Navisworks 2020 for example.
    - Using any version of Navisworks 2016-2020, you will still be able to open previous version of Navisworks files such as 2013,2014,2015, but pre-2016 versions of Navisworks will not be able to open 2016-2020 Navisworks files.
    - Another things to consider. License usage, I agree with statements above, that using the same licence year pool, helps reducing licence usage, and reducing management of licences.
  1. Revit - IFC versions
    Last Post: July 19th, 2017, 06:43 AM
  2. New IFC versions in Revit.
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: April 20th, 2017, 07:31 AM
  3. Update Versions
    Last Post: September 30th, 2014, 07:46 AM
  4. convert Revit multiple 3D views to Navisworks views
    By Ning Zhou in forum Coordination Tools
    Last Post: April 19th, 2014, 03:50 AM
  5. Older versions
    By rubensjr1 in forum Architecture and General Revit Questions
    Last Post: June 27th, 2013, 03:00 AM
