Thread: Hi- problems with creation of families and insert family
    July 7, 2019
    6
    11:23 PM
    I have created a family, I charge it in the other file, but I cannot see it... I checked in you tube videos, and maybe has something to do with the visibility? I checked all the possible types of elements as visible on the View -Visibilty/Graphics Menu...
    I also have noticed that I cannot see the family in the roll menu in properties, the one that I want to insert is not there... where are located anyway? there must be a folder inside Revit?
    Ups, I am pretty lost...
    Thank you in advance
    1,452
    12:23 AM
    If you make a family you need to load it into your project in order to use it. It will only then be added to your project and will stay in there untill you choose to remove (purge) it from the project. Every time you edit the family you have to realod it into your project again and you will get asked if you want to override it or not.
    July 7, 2019
    6
    11:23 PM
    I did itttttt!!!
    thanks so much!
  1. Revit Families Creation
    By hughiesparks27 in forum Architecture - Family Creation
    Last Post: November 11th, 2016, 08:59 AM
  2. Detail level problems in family creation
    By Aleksander in forum Structure - Family Creation
    Last Post: April 18th, 2015, 10:29 AM
  3. Stairs creation problems
    By kohinoor1 in forum Architecture - Family Creation
    Last Post: August 31st, 2012, 09:01 AM
  4. Live Session - Family Creation Series | Intro to Families
    By rkitect in forum Live Sessions - Archive
    Last Post: May 21st, 2012, 06:29 PM
  5. insert specific tag in family
    By ikinks in forum Architecture - Family Creation
    Last Post: May 5th, 2011, 06:33 AM
