Thread: How to set default Mark values for Windows & Doors?
    December 8, 2014
    7
    08:10 AM
    Many of our window and door families are built with nested doors and windows. In the family editor, I can set the instance parameter for Mark, but when I load it into the template and select "Overwrite the existing version and its parameter values" the Mark value defaults to some other value.
    Suggestions how to get around this?
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,498
    08:10 AM
    Mark values are unique to each instance, so Revit doesn't overwrite that parameter. It won't voluntarily create identical Mark values, and you'll get a warning if you do so manually. If you want multiple windows to have the same value, use the Type Mark.
    We use the type mark parameter to note identical windows, and the Mark parameter for doors. We filter out all the nested door/window components, and only schedule the host element in our door schedule.
    10,617
    09:10 AM
    I suggest having Dynamo fix the numbers after the fact. What we are given in Revit (in terms of predefining Mark and Type Mark Values) in the Family Editor, is a joke.
  1. Duplicate type mark for same windows
    By rabbitcookies in forum Architecture and General Revit Questions
    Last Post: July 19th, 2016, 04:07 PM
  2. Equipment Mark values in Panel Schedules
    By robbbbi in forum MEP - General
    Last Post: December 12th, 2015, 10:46 AM
  3. Replies: 11
    Last Post: October 30th, 2015, 05:19 PM
  4. elements have duplicate 'Mark' / 'Number' values
    By mno in forum Architecture and General Revit Questions
    Last Post: September 13th, 2012, 10:20 AM
  5. Inside the System: Default Load Values
    Last Post: February 9th, 2012, 08:45 AM
